Object reference not set to an instance of an object - не может найти connectionStrings
Здравствуйте! у меня такая проблема: webconfig: Код: xml 1. 2. 3. 4. код: Код: c# 1. 2. вроде все очень просто и работало в миллионе других случаев, а сейчас выдает ошибку: =================================================================================== Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: Line 580: Line 581: ConnectionStringSettings conn1 = ConfigurationManager.ConnectionStrings["base1"]; Line 582: DbConnection connection1 = new SqlConnection(conn1.ConnectionString); Line 583: Line 584: Source File: C:\_prj1_new\m8_new\m8_new\Models\assist.cs Line: 582 Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] m8_project.Models.assist.update_insert_ALL(List`1 name_list, List`1 value_list, List`1 type_list, List`1 name_list_where, List`1 value_list_where, List`1 type_list_where, String command_text, String table_name, String update_insert_select, String base_name) in C:\_prj1_new\m8_new\m8_new\Models\assist.cs:582 m8_project.Models.M8.m8_iu.update_status(Int32 seller, String base_name) in C:\_prj1_new\m8_new\m8_new\Models\M8\m8_iu.cs:46 m8_project.Models.M8.m8_new.fill_sparts_list_VERY_NEW(String id) in C:\_prj1_new\m8_new\m8_new\Models\M8\m8_new.cs:35 m8_project.Controllers.m8Controller.fill_sparts_list_word_counter(String id) in C:\_prj1_new\m8_new\m8_new\Controllers\m8Controller.cs:110 lambda_method(Closure , ControllerBase , Object[] ) +108 System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) +17 System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +205 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +27 System.Web.Mvc.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() +55 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +263 System.Web.Mvc.<>c__DisplayClass17.<InvokeActionMethodWithFilters>b__14() +19 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +191 System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +343 System.Web.Mvc.Controller.ExecuteCore() +116 System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +97 System.Web.Mvc.ControllerBase.System.Web.Mvc.IController.Execute(RequestContext requestContext) +10 System.Web.Mvc.<>c__DisplayClassb.<BeginProcessRequest>b__5() +37 System.Web.Mvc.Async.<>c__DisplayClass1.<MakeVoidDelegate>b__0() +21 System.Web.Mvc.Async.<>c__DisplayClass8`1.<BeginSynchronous>b__7(IAsyncResult _) +12 System.Web.Mvc.Async.WrappedAsyncResult`1.End() +62 System.Web.Mvc.<>c__DisplayClasse.<EndProcessRequest>b__d() +50 System.Web.Mvc.SecurityUtil.<GetCallInAppTrustThunk>b__0(Action f) +7 System.Web.Mvc.SecurityUtil.ProcessInApplicationTrust(Action action) +22 System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +60 System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +8967885 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +184 ... |
| 19.08.2012, 02:11 |
что это? проект компилируется нормально, база на месте, ее можно из Visual Studio редактировать - она доступна. Уже и названия менял и разные базы подставлял - все время одна и та же ошибка. Помогите! Заранее большое спасибо! ... |
| 19.08.2012, 02:15 |
по моему дело должно быть так ConnectionStringSettings conn1 = ConfigurationManager.ConnectionStrings["base1"].ConnectionString; ... |
| 19.08.2012, 10:58 |
rusik48, а в дебагере посмотреть что хранится в conn1 ??? ... |
| 20.08.2012, 11:13 |
Deza, оно равно null но это ж блин противоречит всем законам физики!!! (с) ... |
| 20.08.2012, 14:26 |
rusik48, сколько у тебя проектов в солюшене? ... |
| 20.08.2012, 14:33 |
rusik48Deza, оно равно null но это ж блин противоречит всем законам физики!!! (с) Код: c# 1. а так? ... |
| 20.08.2012, 14:36 |
Deza, та же ошибка Object reference not set to an instance of an object ----- проектов в солюшене - 1, и 2-й это тест, но я его не трогал. ну в общем пока решение только такое: 1. взял архивную копию проекта 2. добавил в нее последние изменения и все работает. те же самые строки которые тут не работают - в архиве работают. всем большое спасибо! ... |
| 21.08.2012, 00:03 |
rusik48, Иногда в студии возникает ничем не объяснимый глюк, когда проект начинает "рушиться" с такими вот странными иксепшнами. Никакие очистки и перестройки не помогают. Помогает перезаливка из архива или даже просто смена локации проекта. Я такое замечал раза два. ... |
| 21.08.2012, 11:03 |
start [/forum/topic.php?desktop=1&fid=18&tid=1359309]: |
157ms |
26ms |
| others: | 245ms |
| total: | 455ms |
