ADO и DBF-файлы. Доступ к телу
Люди добрые, есть такой код: connect = Server.CreateObject("ADODB.Connection"); connect.ConnectionTimeout = 15; connect.CommandTimeout = 10; connect.Open("DSN=BAD"); var cmd = Server.CreateObject("ADODB.Command"); Все круто работает.. ("DSN=BAD") -- ODBC-соединение с источником данных (папка с dbf-файлами). Как можно к ним достучаться еще в обход ODBC? Если можно, то примечик, плз. ... |
| 31.08.2005, 17:47:54 |
1) Надо установить Microsoft OLE DB Provider for Visual FoxPro 9.0 (vfpoledb.exe) с микрософта 2) Пример кода ниже. Все дбф в C:\MACIR\Data, имена соотв. именам таблиц. Dim conn As New OleDbConnection("Provider=VFPOLEDB.1; Data Source=C:\MACIR\Data;") Dim Command As New OleDbCommand Command.Connection = conn Command.CommandText = "SELECT ID,FirstName,LastName,Company,Address,City,State,ZipCode,Country,Phone,Fax " + _ "FROM Subs WHERE FirstName='" & UCase(cAdr.FirstName) & "' AND LastName='" & UCase(cAdr.LastName) & "'" conn.Open() Dim DBFReader As OleDbDataReader DBFReader = Command.ExecuteReader() Dim MACIRAdr As Address If DBFReader.HasRows Then While DBFReader.Read() MACIRAdr.id = Trim(DBFReader.GetValue(0)) MACIRAdr.FirstName = Trim(DBFReader.GetString(1)) MACIRAdr.LastName = Trim(DBFReader.GetString(2)))) MACIRAdr.Zip = Trim(DBFReader.GetString(7)) If MACIRAdr.FirstName = UCase(cAdr.FirstName) _ And MACIRAdr.LastName = UCase(cAdr.LastName) _ And MACIRAdr.Zip = UCase(cAdr.Zip) Then DBFReader.Close() Return MACIRAdr.id 'Same user End If End While DBFReader.Close() Else 'create user in MACIR 'get next SUBID to create new subscriber DBFReader.Close() Command.CommandText = "Select ID FROM SUBID" DBFReader = Command.ExecuteReader() DBFReader.Read() Dim SUBID As Integer = Trim(DBFReader.GetValue(0)) DBFReader.Close() 'increment SUBID Command.CommandText = "UPDATE SUBID SET ID=" & SUBID + 1 Command.ExecuteNonQuery() 'insert into SUBS If cAdr.Country = "CA" Then cAdr.Country = "CAN" End If Command.CommandText = "Insert into SUBS (" + _ "ID,SALUTE,FirstName,LastName,TITLE,Company," + _ "COMPCODE,MAILSTOP,Address,City,State," + _ "ZipCode,Country,Phone,Fax," + _ "FSA,COMMENTS,BADADDR,RENTLIST) VALUES " + _ "(" & SUBID & ",'','" & cAdr.FirstName & "','" & cAdr.LastName & "','','" & cAdr.Company & "'," + _ "'','','" & cAdr.Address1 & cAdr.Address2 & "','" & cAdr.City & "','" & cAdr.State & "'," + _ "'" & cAdr.Zip & "','" & cAdr.Country & "','" & cAdr.Phone & "','" & cAdr.Fax & "'," + _ "0,'','',?)" Dim logical As Object Command.Parameters.Add("@RENTLIST", logical).Value = True Try Command.ExecuteNonQuery() Catch ex As Exception Console.WriteLine(ex.ToString) End Try ... ... |
| 01.09.2005, 21:16:27 |
DBF с OleDbProvider=VFPOLEDB.1 После "успешного" отката захожу в SUBID.DBF и вижу там неоткатившееся 1111, вместо исходного 1756. Может кто знает в чем дело. Огромное спасибо! Dim myConnection As New OleDbConnection("Provider=VFPOLEDB.1;" + _ "Data Source=C:\MACIR\Data;") myConnection.Open() Dim myCommand As OleDbCommand = myConnection.CreateCommand() Dim myTrans As OleDbTransaction ' Start a local transaction myTrans = myConnection.BeginTransaction(IsolationLevel.ReadCommitted) ' Assign transaction object for a pending local transaction myCommand.Connection = myConnection myCommand.Transaction = myTrans Try myCommand.CommandText = "UPDATE SUBID SET ID=1111" myCommand.ExecuteNonQuery() 'Изначально ошибочная команда для выполнения Rollback: myCommand.CommandText = "Insert into SUBID (ID) VALUES ('103')" myCommand.ExecuteNonQuery() myTrans.Commit() Console.WriteLine("Both records are written to database.") Catch e As Exception Try myTrans.Rollback() Catch ex As OleDbException If Not myTrans.Connection Is Nothing Then Console.WriteLine("An exception of type " & ex.GetType().ToString() & _ " was encountered while attempting to roll back the transaction.") End If End Try Console.WriteLine("An exception of type " & e.GetType().ToString() & _ "was encountered while inserting the data.") Console.WriteLine("Neither record was written to database.") Finally myConnection.Close() End Try ... |
| 01.09.2005, 21:49:43 |
start [/forum/topic.php?desktop=1&fid=17&tid=1353591]: |
159ms |
37ms |
| others: | 197ms |
| total: | 438ms |
