To judje: some error occured.
Лазил тут у вас по сайту - глюки были. Вот вам один из них: Server Error in '/' Application. SQL Server does not exist or access denied. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.SqlClient.SqlException: SQL Server does not exist or access denied. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [SqlException: SQL Server does not exist or access denied.] System.Data.SqlClient.ConnectionPool.GetConnection(Boolean& isInTransaction) +474 System.Data.SqlClient.SqlConnectionPoolManager.GetPooledConnection(SqlConnectionString options, Boolean& isInTransaction) +372 System.Data.SqlClient.SqlConnection.Open() +386 actualadv.ActualAdvEngine.GetBanner() actualadv.actualadvert.Page_Load(Object sender, EventArgs e) System.Web.UI.Control.OnLoad(EventArgs e) +67 System.Web.UI.Control.LoadRecursive() +35 System.Web.UI.Page.ProcessRequestMain() +731 Version Information: Microsoft .NET Framework Version:1.1.4322.573; ASP.NET Version:1.1.4322.573 ... |
| 02.09.2003, 12:31:00 |
start [/forum/topic.php?fid=8&gotonew=1&tid=47037]: |
26ms |
52ms |
68ms |
| others: | 247ms |
| total: | 463ms |
