Модератор/Администратор, Что за беда?
Вот выплюнуло это. Server Error in '/' Application. -------------------------------------------------------------------------------- Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. Parser Error Message: ? Source Error: Line 257: <add assembly="System.EnterpriseServices, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/> Line 258: <add assembly="System.Web.Mobile, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/> Line 259: <add assembly="*"/> Line 260: </assemblies> Line 261: Source File: c:\windows\microsoft.net\framework\v1.1.4322\Config\machine.config Line: 259 Assembly Load Trace: The following information can be helpful to determine why the assembly 'ActualForum' could not be loaded. === Pre-bind state information === LOG: DisplayName = ActualForum (Partial) LOG: Appbase = file:///D:/InetPub/sql.ru/LocalUser/sql LOG: Initial PrivatePath = bin Calling assembly : (Unknown). === LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind). LOG: Post-policy reference: ActualForum LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/501a40f2/c4e5af7/ActualForum.DLL. LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/501a40f2/c4e5af7/ActualForum/ActualForum.DLL. LOG: Attempting download of new URL file:///D:/InetPub/sql.ru/LocalUser/sql/bin/ActualForum.DLL. ... |
| 23.09.2004, 22:12:00 |
Подозреваю, что это Judge заливал новую версию. 1.4i ... |
| 24.09.2004, 02:39:00 |
| 30.09.2004, 16:18:00 |
Да уж... :( ... |
| 30.09.2004, 16:48:00 |
Green2 Сервер лежит. ... |
| 30.09.2004, 16:52:00 |
Green2 Через NNTP он просто летает! WWW тормозит. Неожиданно... ... |
| 30.09.2004, 17:02:00 |
автор Похоже на то... Хотя запросы напрямую к SQL server проходят не очень быстро, COUNT(*) по таблице сообщений форумов выполнялся 10 сек. :( надо кинуть план выполнения запроса в форум по MSSQL совместными усилиями разрешится трабла ... |
| 01.10.2004, 13:19:00 |
УРААА !!! все заработало!!!! ... |
| 01.10.2004, 16:43:00 |
#1003003
Эк точно, блин весь день мне SQL.RU показывал пустые форумы! Как-будто в них и ничего нет! И пожаловаться не получалось, все в хлам тормазило (([img]http://for.h12.ru/forum/images/smiles/icon_redface.gif[/img][img]http://for.h12.ru/forum/images/smiles/icon_redface.gif[/img][img]http://for.h12.ru/forum/images/smiles/icon_redface.gif[/img] ... |
| 01.10.2004, 17:09:00 |
start [/forum/topic.php?fid=8&gotonew=1&tid=124961]: |
28ms |
44ms |
77ms |
| others: | 298ms |
| total: | 522ms |
