покритикуйте резюме плиз, с точки зрения ангилйского.
ver 1.2 SERGEY I. Tel. +7903-: Email: @yandex.ru, ICQ# Objectives: Work as a Business Intelligence/DWH Designer, or Data Base Developer. Professional Summary: • Experienced programmer/analyst, 15 years of progressive experience in DBMS design, developing and support. • Over 10 years experience as a DBMS developer/Data warehousing. • Business areas: accounting and logistics, Telecommuniation and financial systems. These include Accounting and logistics, Telecommuniation and Financial Systems. Application software expertise includes strong programming skills using Oracle PL/SQL, Data Warehouse, T-SQL, Delphi 2-6, C#. Strong report writing skills using varios tools like Business Objects 6.5, MSAccess97, Delphi Report Smith. Have knowledge Oracle and MSSQL 2000 Database Administration. Technical Skills: • BI Tools: Business Objects 6.5 • RDBMS: Oracle 9.x, MSSQL 2000, MSAccess97 • Database technologies: SQL, T-SQL, PL-SQL, DAO, ADO, • RAD: Delphi 2-6, C#. • Client/Server and report technologies: Visual Basic, Delphi.Delphi Report Smith. • Operating systems: All Windows systems, WinAPI, familiar with Linux and Unix. • Proficiency in MS-DOS/Windows utilities and scripts, MS Office Experience: July 2006 - present XXXXX Russia, Moscow. Business Intelligence consultant. Business area: BI/DWH solution for major Russian Telecommunication operator. • End-user report development, from requirement gathering to design, build, test, deploy • writing and testing reports utilizing Business Objects 6.5 • Designing and implementing BI technical and operational architecture / frameworks • Data modelling and data architecture design / implementation • ETL, data integration and data conversion design / implementation • Developing PL/SQL procedures & functions to support the reports by retrieving the data from the data warehousing application. • migrating and automating existing reports to support day to day requests • reviewing and updating reports to conform to the Business Analytics & Reporting team development standards July 2005 - June 2006 XXXXX Russia, Moscow. Software developer. Business area: n-tier Application server for remote data gathering solution. • Completed object and data modeling, logic, tested and implemented a C# GUI and MS-SQL Back End for data processing. • Documented Tech Specs for the proposed data base design. May 2004 - June 2005 XXXXX company,Russia, Moscow. Software developer. Business area: Client/Server Application for automotive parts distributor. • Developed custom finance and logistic applications with Delphi in a Client/Server environment using Microsoft SQLServer 2000 and WIN XP workstations. • Developed T-SQL procedures for the back end processing of the proposed data base design. April 2003- May 2004 XXXXX company,Russia, Moscow. Software developer. Business area: Client/Server Application for stationery distributor. • Created and implemented model for business process, design data structure and developing an application for local warehouse (MS-SQL 2000, Delphi 6.0). • Completed object and data modeling, logic, tested and implemented of a Delphi GUI and MS-SQL Back End for data entry and retrieval. July 2001- February 2003 XXXXX company, Dniepropetrovsk. Software developer. • Developed custom finance and logistic applications with Delphi in a Client/Server environment using Microsoft SQLServer 2000 and WIN XP workstations. • Completed object and data modeling, logic, tested and implemented a Delphi GUI and MS-SQL Back End for data entry and retrieval. February 1998-July 2001 XXXXX, Dniepropetrovsk. Software developer. • Created and implemented model for business process, designed data structure and developed an application for local warehouse (Access 97, Visual Basic). • Completed object and data modeling, logic, tested and implemented a VB GUI and Access Back End for data entry and retrieval. • Installed and supported local area network based on IPX/SPX, TCP/IP protocols (Netware, SCO Unix). August 1992 -- February 1998 XXXXX, Enakievo. Network specialist/Software Developer. • Foxpro, Delphi, Access 97, Visual Basic RDBMS design, planning, developing and support, including financial, economical. • Installed and supported local area network based on IPX/SPX, TCP/IP protocols (Netware, SCO Unix). Education: 1985-1992 The Dnepropetrovsk State University, Dnepropetrovsk , Ukraine Department of Radiotechnics; B.Sc. in software engineering, 1992. Brainbench Certifications: Код 1. 2. 3. ... |
| 07.05.2008, 14:41 |
Sergey3 javajdbc В том то и дело что бизнес финкции не указаны ни в титле, ни в деталях. Хоть гденибудь -- и будет уже лучше. Насчет Аналиста -- 100% на последнем - телеком. но внутри телекома кроме биллинга еще есть и финансы, которые получаются из этого биллинга. т.е. формально - я могу писать финансы? или все-таки только телеком - а уж что там внутри - разберемся на интервью?:) и про аналиста с консультантом: aналист - это же вроде человек, пишущий спеки? нет? да, резюме скорее для Канады. PS Аналист совсем не обязательно пишет спеки. Часто тот же девелопер. Просто должность так называется. Но консультант (как я уже написал) имеет совсем другой смысл. ... |
| 07.05.2008, 17:54 |
ver 1.2.jj SERGEY I. Tel. +7903-: Email: @yandex.ru Objectives: Business Intelligence / Data Warehouse Designer, Database Developer. Summary: • Experienced programmer/analyst, 15 years of wide-range experience in DBMS design, developing and support. • Over 10 years experience as a DBMS / Data Warehousing developer. • Business areas: accounting, logistics, telecommunication and financial systems. Professional Skills: • BI Tools: Business Objects 6.5 • DBMS: Oracle 9.x, MSSQL 2000, MSAccess97 • Database technologies: SQL, T-SQL, PL-SQL, DAO, ADO, • RAD: Delphi 2-6, C#. • Client/Server and report technologies: Visual Basic, Delphi.Delphi Report Smith. • Operating systems: All Windows systems, WinAPI, familiar with Linux and Unix. • Proficiency in MS-DOS/Windows utilities and scripts, MS Office Experience: 2006 - present XXXXX Moscow, Russia. Business Intelligence consultant. Business area: BI/DWH solution for major Russian Telecommunication operator. • End-user report development, from requirement gathering to design, build, test, deploy • Writing and testing reports utilizing Business Objects 6.5 • Designing and implementing BI technical and operational architecture / frameworks • Data modeling and data architecture design / implementation • ETL, data integration and data conversion design / implementation • Developing PL/SQL procedures and functions to support the reports by retrieving the data from the data warehousing application. • migrating and automating existing reports to support day to day requests • reviewing and updating reports to conform to the Business Analytics & Reporting team development standards 2005-2006 XXXXX, Moscow, Russia. Software developer. Business area: n-tier Application server for remote data gathering solution. • Completed object and data modeling, logic, tested and implemented a C# GUI and MS-SQL Back-end for data processing. • Documented Tech Specs for the proposed data base design. May 2004 - June 2005 XXXXX, Moscow, Russia. Software developer. Business area: Client/Server Application for automotive parts distributor. • Developed custom finance and logistic Client/Server applications using Delphi, Microsoft SQLServer 2000 and Windows XP workstations. • Developed T-SQL procedures for the back-end data processing. * Implemented model-level business rules. April 2003- May 2004 XXXXX , Moscow, Russia. Software developer. Business area: Client/Server Application for distributor of retail products. • Designed and implemented model for business process, design data structure and developing an application for local warehouse using MS-SQL 2000 and Delphi 6.0. • Completed object and data modeling, logic, tested and implemented of a Delphi GUI and MS-SQL Back-end for data entry and retrieval. 2001-2003 XXXXX, Dnepropetrovsk. China (?) Software developer. • Developed custom finance and logistic applications with Delphi in a Client/Server environment using Microsoft SQLServer 2000 and WIN XP workstations. • Completed object and data modeling, logic, tested and implemented a Delphi GUI and MS-SQL Back End for data entry and retrieval. 1998-2001 XXXXX, Dniepropetrovsk. Brazil (?) Software developer. • Created and implemented model for business process, designed data structure and developed an application for local warehouse (Access 97, Visual Basic). • Completed object and data modeling, logic, tested and implemented a VB GUI and Access Back End for data entry and retrieval. • Installed and supported local area network based on IPX/SPX, TCP/IP protocols (Netware, SCO Unix). 1992-1998 XXXXX, Enakievo. Uganda (?) Network specialist/Software Developer. • Created and supported finance application using Foxpro, Delphi, Access 97, Visual Basic RDBMS. • Installed and supported local area network based on IPX/SPX, TCP/IP protocols on Netware and SCO Unix platforms. Education: 1992 B.Sc. in Software Engineering. State University, Dnepropetrovsk , Ukraine. Brainbench Certifications: 2008. RDBMS Concepts 2006. Java 1 ... |
| 07.05.2008, 18:14 |
Leonid Gurevich Sergey3 javajdbc ... на последнем - телеком. но внутри телекома кроме биллинга еще есть и финансы, которые получаются из этого биллинга. т.е. формально - я могу писать финансы? или все-таки только телеком - а уж что там внутри - разберемся на интервью?:) и про аналиста с консультантом: aналист - это же вроде человек, пишущий спеки? нет? да, резюме скорее для Канады. PS Аналист совсем не обязательно пишет спеки. Часто тот же девелопер. Просто должность так называется. Но консультант (как я уже написал) имеет совсем другой смысл. Тут уж сам автор должен раскрывать тему... ... |
| 07.05.2008, 18:21 |
Месяцы можно все убрать... ... |
| 07.05.2008, 18:27 |
javajdbc Кодеров без бизнез знаний -- полно. Имено решение бизнез зада4 ценится. ... |
| 07.05.2008, 18:36 |
Еще очень хорошо в резюме показывать, что умеешь быстро постигать новое, учиться. Например, написать, что пришел в новый проект, в котором ни в зуб ногой, а через пару-тройку недель уже смог работать на уровне с остальными разработчиками. На интервью любят задавать вопросы по самообучаемости. ... |
| 07.05.2008, 18:43 |
Leonid Gurevich javajdbc Кодеров без бизнез знаний -- полно. Имено решение бизнез зада4 ценится. ... |
| 07.05.2008, 18:44 |
Sergey3 Ursego ...И ни слова про языки (у них даже мысли о плохом английском не должно зародиться, зачем лишний раз напоминать!) ... |
| 08.05.2008, 19:28 |
Leonid Gurevich Но консультант (как я уже написал) имеет совсем другой смысл. ... |
| 08.05.2008, 19:31 |
Leonid Gurevich Но простое упоминане базнес функции конторы ничего не говорит о том, какими бизнес знаниями обладает человек, который работал в ней. Здесь нужно тогда указывать конкретные проекты и свою роль в них. Есть большая компания, со своим хранилищем данных. на нем строится отчетность, в т.ч. оперативная, аналитическая, финансовая, ГААП. компания иногда покупает конкурентов в других странах, и после покупки ставит там свое хранилище, и переделывает местную старую отчетность под свои стандарты и инструменты(Business Objects). мы(я) ставлю отчеты из головной конторы в местные филиалы и адаптирую их под местные особенности, иногда ваяю новые отчеты, которых не было в предыдущих версиях. в процессе эксплуатации хранилища отвечаю на вопросы аналитиков и бизнес-юзеров типа: а что значит этот показатель в отчете? а почему эти 2 суммы в разных отчетах не сопадают, по идее должны? а почему т.е. это можно, конешно перевести, но это ж просто эссе какое-то получается. ... |
| 14.05.2008, 13:48 |
По-моему, всё, что вам нужно раскрыть в резюме, так только вот это.
Sergey3 мы(я) ставлю отчеты из головной конторы в местные филиалы и адаптирую их под местные особенности, иногда ваяю новые отчеты, которых не было в предыдущих версиях. ... |
| 14.05.2008, 18:03 |
ну, наверное, окончательный вариант 2006 - present XXXXX Moscow, Russia. Business Intelligence consultant. Business area: BI/DWH solution for major Russian Telecommunication operator. • Designing and implementing corporate reporting system in 6 branches in different countries. • End-user report development, from requirement gathering to design, build, test, deploy • Writing and testing reports utilizing Business Objects 6.5 • Designing and implementing BI technical and operational architecture / frameworks • Data modeling and data architecture design / implementation • ETL, data integration and data conversion design / implementation • Developing PL/SQL procedures and functions to support the reports by retrieving the data from the data warehousing application. • migrating and automating existing reports to support day to day requests • reviewing and updating reports to conform to the Business Analytics & Reporting team development standards WBR, Serge ... |
| 21.05.2008, 15:43 |
Смутило:
Sergey3 • Developing PL/SQL procedures and functions to support the reports by retrieving the data from the data warehousing application. Sergey3 • Developing PL/SQL procedures and functions to support the reports by retrieving the data from the warehouse database. ... |
| 21.05.2008, 16:50 |
start [/forum/topic.php?fid=7&gotonew=1&tid=553697]: |
73ms |
66ms |
| others: | 250ms |
| total: | 456ms |
