Exel-VB-"сводная таблица" вручную!
Есть таблица из 10 колонок, 1 и 2 колонка- количество, чтобы сделать "сводную таблицу" вручную (т.к. не нашел как убрать "merge" из настоящей сводной таблицы) получился вот такой длиный "Sub"!!! Все одинаковые наименования объединяются и суммируются, пустые строки удаляются! Может кто знает более рациональное решение? ------------------------------------------------------ Sub Optim() Dim i As Integer Dim j As Integer For i = 4 To 51 For j = i + 1 To 51 If (IsEmpty(Sheet1.Cells(j, 1))) And (IsEmpty(Sheet1.Cells(j, 2))) Then GoTo 10 End If '----------------------------------------------------------- If (Sheet1.Cells(i, 3) = Sheet1.Cells(j, 3)) _ And (Sheet1.Cells(i, 4) = Sheet1.Cells(j, 4)) _ And (Sheet1.Cells(i, 5) = Sheet1.Cells(j, 5)) _ And (Sheet1.Cells(i, 6) = Sheet1.Cells(j, 6)) _ And (Sheet1.Cells(i, 7) = Sheet1.Cells(j, 7)) _ And (Sheet1.Cells(i, 8) = Sheet1.Cells(j, 8)) _ And (Sheet1.Cells(i, 9) = Sheet1.Cells(j, 9)) _ And (Sheet1.Cells(i, 10) = Sheet1.Cells(j, 10)) Then '----------------------------------------------------- Sheet1.Cells(j, 3) = 0 Sheet1.Cells(j, 4) = 0 Sheet1.Cells(j, 5) = 0 Sheet1.Cells(j, 6) = 0 Sheet1.Cells(j, 7) = 0 Sheet1.Cells(j, 8) = 0 Sheet1.Cells(j, 9) = 0 Sheet1.Cells(j, 10) = 0 Sheet1.Cells(i, 1) = Sheet1.Cells(i, 1) + Sheet1.Cells(j, 1) Sheet1.Cells(i, 2) = Sheet1.Cells(i, 2) + Sheet1.Cells(j, 2) Sheet1.Cells(j, 1) = 0 Sheet1.Cells(j, 2) = 0 10 End If Next j Next i '=========================================================== For i = 4 To 51 If Sheet1.Cells(i, 1) = 0 Then For j = i + 1 To 51 If Not Sheet1.Cells(j, 1) = 0 Then '----------------------------------------------------------- Sheet1.Cells(i, 1) = Sheet1.Cells(j, 1) Sheet1.Cells(i, 2) = Sheet1.Cells(j, 2) Sheet1.Cells(i, 3) = Sheet1.Cells(j, 3) Sheet1.Cells(i, 4) = Sheet1.Cells(j, 4) Sheet1.Cells(i, 5) = Sheet1.Cells(j, 5) Sheet1.Cells(i, 6) = Sheet1.Cells(j, 6) Sheet1.Cells(i, 7) = Sheet1.Cells(j, 7) Sheet1.Cells(i, 8) = Sheet1.Cells(j, 8) Sheet1.Cells(i, 9) = Sheet1.Cells(j, 9) Sheet1.Cells(i, 10) = Sheet1.Cells(j, 10) '------------------------------------------------------- Sheet1.Cells(j, 1) = 0 Sheet1.Cells(j, 2) = 0 Sheet1.Cells(j, 3) = 0 Sheet1.Cells(j, 4) = 0 Sheet1.Cells(j, 5) = 0 Sheet1.Cells(j, 6) = 0 Sheet1.Cells(j, 7) = 0 Sheet1.Cells(j, 8) = 0 Sheet1.Cells(j, 9) = 0 Sheet1.Cells(j, 10) = 0 Exit For End If Next j End If Next i ... |
| 26.10.2004, 23:17:16 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2186474]: |
55ms |
39ms |
| others: | 237ms |
| total: | 385ms |
