Connect to Informix
Privet vsem, Mne nujno sdelat' connect k Informix-DataBase. K soshaleniu nepoluchaetsja :( Err.Description pishet, chto slishkom dlinnoe imja u 'myDSN'. Moshet li kto nibud' pomotch?? Private Sub myConn() On Error GoTo Fl Dim conn As New ADODB.Connection Dim rs1 As New ADODB.Recordset Dim qr Dim myDSN As String myDSN = "C:\...\ODBC\Data Sources\dbconn.dsn" conn.Open myDSN, User, Pass qr= "select ..." rs1.Open qr, conn, adOpenKeyset, adLockReadOnly ................................. rs1.Close conn.Close Fl: Debug.Print Err.Number Debug.Print Err.Description Debug.Print Err.Source End Sub zaranee spasibo ... |
| 17.01.2006, 15:48:49 |
Connect to Informix
Используй лучше вместо файла соединения ConnectionString conn.ConnectionString = "................................." conn.Open ... |
| 17.01.2006, 16:00:00 |
Connect to Informix
Tak??? conn.ConnectionString = "Driver={INFORMIX 3.30 32 BIT};" & _ "database=xxx;" & _ "server=xxx;" & _ "host=xxx;" & _ "uid=xxx;" & _ "password=xxx;" & _ "protocol=xxx;" & _ "service=xxx" k soshaleniu toshe ne rabotaet ... |
| 17.01.2006, 16:29:52 |
Connect to Informix
Проверь строку подключения на www.connectionstrings.com . ... |
| 17.01.2006, 16:57:18 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2185355]: |
36ms |
28ms |
| others: | 187ms |
| total: | 291ms |
