Форумы / Microsoft Office [игнор отключен] [закрыт для гостей] / Hook в VBA (Excel)
Hook в VBA (Excel)
    #33653494
Kamsky
Можно ли повесить hook при помощи VBA (MS Exel ) без DLL?
Попробовал такой вариант:
'API functions to be used
Public Declare Function CallNextHookEx Lib "user32" (ByVal hHook As Long, _
ByVal ncode As Long, ByVal wParam As Long, lParam As Any) As Long
Public Declare Function GetModuleHandle Lib "kernel32" Alias "GetModuleHandleA" (ByVal lpModuleName As String) As Long
Public Declare Function SetWindowsHookEx Lib "user32" Alias "SetWindowsHookExA" _
(ByVal idHook As Long, ByVal lpfn As Long, ByVal hmod As Long, _
ByVal dwThreadId As Long) As Long
Public Declare Function UnhookWindowsHookEx Lib "user32" (ByVal hHook As Long) As Long
Public Declare Function GetCurrentThreadId Lib "kernel32" () As Long
'Constants to be used in our API functions
Public Const EM_SETPASSWORDCHAR = &HCC
Public Const WH_CBT = 5
Public Const HCBT_ACTIVATE = 5
Public Const HC_ACTION = 0
Public Const WH_KEYBOARD = 2
Public hHook As Long
Function Keyboard(ByVal idHook As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
If idHook >= 0 Then
'Process keys you want to filter
If wParam = vbKeyReturn Then
MsgBox "!!!!", vbCritical, "gggg"
End If
End If
Keyboard = CallNextHookEx(hHook, idHook, wParam, lParam)
End Function
Private Sub Workbook_BeforeClose(Cancel As Boolean)
UnhookWindowsHookEx hHook
End Sub
Private Sub Workbook_Open()
lngThreadID = GetCurrentThreadId
lngModHwnd = GetModuleHandle(vbNullString)
hHook = SetWindowsHookEx(WH_KEYBOARD, AddressOf Keyboard, 0, lngThreadID)
End Sub
не работает! Вернее работает, но Exel зависает на неопределенное время.
