Как обратиться к символу строки?
Добрый день! Как следует обратиться к символу строки? s - не катит s(i) - не катит s. - не катит s.(i) - не катит Как же можно выцепить i-й символ из строки ? ... |
| 23.08.2006, 13:09:10 |
Код: plaintext 1. 2. 3. 4. 5. ... |
| 23.08.2006, 13:10:15 |
Mid Function Returns a Variant (String) containing a specified number of characters from a string. Syntax Mid(string, start[, length]) The Mid function syntax has these named arguments: Part Description string Required. String expression from which characters are returned. If string contains Null, Null is returned. start Required; Long. Character position in string at which the part to be taken begins. If start is greater than the number of characters in string, Mid returns a zero-length string (""). length Optional; Variant (Long). Number of characters to return. If omitted or if there are fewer than length characters in the text (including the character at start), all characters from the start position to the end of the string are returned ... |
| 23.08.2006, 13:40:00 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2184415]: |
55ms |
54ms |
| others: | 246ms |
| total: | 416ms |
