авто
Private Sub CboGod_Change() FrmModel.CmdOk.Default = True FrmModel.CmdCancel.Cancel = True FrmModel.TextMin.Value = 0 FrmModel.TextMax.Value = 0 god = CboGod.Text file = "C:\Íàëè÷èå\Àâòîìîáèëè-" & god & ".xls" FrmModel.LstMarka.Clear Num = 0 ' ************Ïðîâåðêà íà ñóøåñòâîâàíèå ôàéëà ñ òåìàìè If Dir(file) = "" Then MsgBox ("Ôàéë Áä Àâòîìîáèëè-" & god & ".xls íå ñóùåñòâóåò!") Exit Sub End If fil = Right(file, 19) Dim FOpen As Boolean For Each Êíèãà In Workbooks If Êíèãà.Name = fil Then FOpen = True Workbooks(Êíèãà.Name).Activate Worksheets("Ëèñò1").Select Exit For End If Next Êíèãà If FOpen = False Then Workbooks.Open file Worksheets("Ëèñò1").Select End If ' ********** Çàíîñèì òåìû â ìàññèâ Dim NomerStrok As Integer Dim flag As Boolean NomerStrok = 2 kolMarok = 1 Do While Trim(Cells(NomerStrok, 1).Value) <> "" flag = False If flag = False Then ReDim Preserve Marki(kolMarok) Marki(kolMarok) = Trim(Cells(NomerStrok, 1).Value) kolMarok = kolMarok + 1 End If NomerStrok = NomerStrok + 1 Loop '************ Ñîðòèðóåì òåìû ïî àëôàâèòó For i = 1 To kolMarok - 1 For j = 1 To kolMarok - 2 If Marki(j) > Marki(j + 1) Then pervui = Marki(j) Marki(j) = Marki(j + 1) Marki(j + 1) = pervui End If Next j Next i kol = 1 For i = 1 To kolMarok - 1 If Marki(i - 1) <> Marki(i) Then ReDim Preserve Marka(kol) Marka(0) = "ÂÑÅ" Marka(kol) = Marki(i) kol = kol + 1 End If Next i '**************Âûâîäè òåìû â lst ëèñò FrmModel.LstMarka.List = Marka End Sub Private Sub CmdCancel_Click() god = CboGod.Text file = "C:\Íàëè÷èå\Àâòîìîáèëè-" & god & ".xls" fil = Right(file, 19) For Each book In Workbooks If book.Name = fil Then Workbooks(book.Name).Close saveChanges = False Exit For End If Next Unload FrmModel End Sub Private Sub CmdOk_Click() Dim bubmark1 As Boolean Min = SpinBMin.Value Max = SpinBMax.Value For i = 0 To LstMarka.ListCount - 1 If FrmModel.LstMarka.Selected(i) = True Then bubmark1 = True End If Next i If bubmark1 = False Then MsgBox ("Íå âûáðàíà ÌÀÐÊÀ!") Exit Sub End If If (optbDollar Or optbEvro) = False Then MsgBox ("Íå âûáðàíà ÂÀËÞÒÀ!") Exit Sub End If Path = "C:\Íàëè÷èå\" & Date & "" If Dir(Path, vbDirectory) = "" Then 'Ñîçäàíèå ïàïêè,` åñëè å¸ íåò MkDir (Path) End If If optbDollar = True Then file = " " & Min & "$-" & Max & "$.xls" End If If optbEvro = True Then file = " " & Min & "ˆ-" & Max & "ˆ.xls" End If If Dir(Path & "\" & file) = "" Then ' Ñîçäàíèå ôàéëà, åñëè åãî íåò Workbooks.Add.SaveAs (Path & "\" & file) nach = Application.SheetsInNewWorkbook Application.SheetsInNewWorkbook = 1 Workbooks(Workbooks.Count).Worksheets(1).Name = "ÑÏÈÑÎÊ" Application.SheetsInNewWorkbook = nach Else For Each book In Workbooks If book.Name = file Then book.Close saveChanges:=True End If Next ñîîáøåíèå = "Ôàéë " & file & " óæå ñóùåñòâóåò. Çàìåíèòü åãî?" îòâåò = MsgBox(ñîîáøåíèå, vbInformation + vbOKCancel, "Âíèìàíèå") Select Case îòâåò Case vbOK Kill (Path & "\" & file) Workbooks.Add.SaveAs (Path & "\" & file) Workbooks.Open (Path & "\" & file) nach = Application.SheetsInNewWorkbook Application.SheetsInNewWorkbook = 1 Workbooks(Workbooks.Count).Worksheets(1).Name = "ÑÏÈÑÎÊ" Application.SheetsInNewWorkbook = nach Case vbCancel Exit Sub End Select End If Call ramka(stroke) Call sortirovka Unload FrmModel Workbooks(file).save Workbooks("Àâòîìîáèëè-" & CboGod.Text & ".xls").Close saveChanges = False sms = MsgBox("Ñïèñîê ÌÎÄÅËÅÉ ñôîðìèðîâàí!", vbInformation, "Âíèìàíèå") End Sub Sub sortirovka() '*********Çàíîñèì ìàðêè âûáðàííûå â ìàññèâ ********* Dim bubmark1 As Boolean Dim bubmark2 As Boolean Dim flag2 As Boolean Dim dengi3 As Long Min = SpinBMin.Value Max = SpinBMax.Value If optbDollar = True Then file1 = " " & Min & "$-" & Max & "$.xls" End If If optbEvro = True Then file1 = " " & Min & "ˆ-" & Max & "ˆ.xls" End If If FrmModel.LstMarka.Selected(0) = True Then bubmark2 = True End If god = CboGod.Text file = "C:\Íàëè÷èå\Àâòîìîáèëè-" & god & ".xls" If Dir(file) = "" Then MsgBox ("Ôàéë áä Àâòîìîáèëè-" & god & ".xls íå ñóùåñòâóåò!") FrmModel.LstMarka.Clear Exit Sub End If fil = Right(file, 19) Dim FOpen As Boolean For Each Êíèãà In Workbooks If Êíèãà.Name = fil Then FOpen = True Workbooks(Êíèãà.Name).Activate Worksheets("Ëèñò1").Select Exit For End If Next Êíèãà If FOpen = False Then Workbooks.Open file Worksheets("Ëèñò1").Select End If '*****************åñëè âûáèðàåì ìàðêè îòäåëüíî ************ If bubmark2 = False Then For i = 1 To LstMarka.ListCount - 1 If FrmModel.LstMarka.Selected(i) = True Then bubmark1 = True ReDim Preserve bubmark(KolBubmarok) bubmark(KolBubmarok) = Marka(i) KolBubmarok = KolBubmarok + 1 End If Next i NomerStroki = 2 kolMar = 1 dengaMin = SpinBMin.Value dengaMax = SpinBMax.Value strok = 0 Do While Trim(Cells(NomerStroki, 1).Value) <> "" flag = False If flag = False Then ReDim Preserve Marku(kolMar) Marku(kolMar) = Trim(Cells(NomerStroki, 1).Value) End If i = 0 For i = 0 To KolBubmarok - 1 If Marku(kolMar) = bubmark(i) Then valute = Trim(Cells(NomerStroki, 3).Value) valuta = Right(valute, 1) dengi = Trim(Cells(NomerStroki, 3).Value) dangi1 = Right(dengi, 8) dengi2 = Left(dangi1, 6) S = "" n = Len(dengi) For j = 1 To n If Mid(dengi2, j, 1) <> " " Then S = S + Mid(dengi2, j, 1) End If dengi3 = 0 Next j If S <> "" Then dengi3 = Mid(S, 1, 5) End If ReDim Preserve KonMarka(19, strok) '*********************ïðîâåðêà äåíåæíîé âàëþòû****** If optbDollar = True Then If valuta = "$" Then If n > 9 Then flag2 = True Else: flag2 = False End If If flag2 = True Then If dengi3 <= dengaMax Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Next stolb strok = strok + 1 End If End If If flag2 = False Then If dengi3 < dengaMax And dengi3 > dengaMin Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Range("A2").Select Next stolb strok = strok + 1 End If End If End If End If If optbEvro = True Then If valuta = "ˆ" Then If n > 9 Then flag2 = True Else: flag2 = False End If If flag2 = True Then If dengi3 <= dengaMax Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Range("A2").Select Next stolb strok = strok + 1 End If End If If flag2 = False Then If dengi3 < dengaMax And dengi3 > dengaMin Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Next stolb strok = strok + 1 End If End If End If End If End If Next kolMar = kolMar + 1 NomerStroki = NomerStroki + 1 Loop End If '*************** Åñëè ÂÑÅ *************** If bubmark2 = True Then For i = 1 To LstMarka.ListCount - 1 FrmModel.LstMarka.Selected(i) = True ReDim Preserve bubmark(KolBubmarok) bubmark(KolBubmarok) = Marka(i) KolBubmarok = KolBubmarok + 1 Next i NomerStroki = 2 kolMar = 1 dengaMin = SpinBMin.Value dengaMax = SpinBMax.Value strok = 0 Do While Trim(Cells(NomerStroki, 1).Value) <> "" flag = False If flag = False Then ReDim Preserve Marku(kolMar) Marku(kolMar) = Trim(Cells(NomerStroki, 1).Value) End If i = 0 For i = 0 To KolBubmarok - 1 If Marku(kolMar) = bubmark(i) Then valute = Trim(Cells(NomerStroki, 3).Value) valuta = Right(valute, 1) dengi = Trim(Cells(NomerStroki, 3).Value) dangi1 = Right(dengi, 8) dengi2 = Left(dangi1, 6) S = "" n = Len(dengi) For j = 1 To n If Mid(dengi2, j, 1) <> " " Then S = S + Mid(dengi2, j, 1) End If dengi3 = 0 Next j If S <> "" Then dengi3 = Mid(S, 1, 5) End If ReDim Preserve KonMarka(19, strok) '*********************ïðîâåðêà äåíåæíîé âàëþòû****** If optbDollar = True Then If valuta = "$" Then If n > 9 Then flag2 = True Else: flag2 = False End If If flag2 = True Then If dengi3 <= dengaMax Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Range("A2").Select Next stolb strok = strok + 1 End If End If If flag2 = False Then If dengi3 < dengaMax And dengi3 > dengaMin Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Range("A2").Select Next stolb strok = strok + 1 End If End If End If End If If optbEvro = True Then If valuta = "ˆ" Then If n > 9 Then flag2 = True Else: flag2 = False End If If flag2 = True Then If dengi3 <= dengaMax Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Range("A2").Select Next stolb strok = strok + 1 End If End If If flag2 = False Then If dengi3 < dengaMax And dengi3 > dengaMin Then For stolb = 1 To 19 KonMarka(19, strok) = Cells(NomerStroki, stolb).Value stroke = strok + 4 Workbooks(file1).Sheets(1).Cells(stroke, stolb).Value = KonMarka(19, strok) Next stolb strok = strok + 1 End If End If End If End If End If Next kolMar = kolMar + 1 NomerStroki = NomerStroki + 1 Loop End If If (bubmark1 Or bubmark2) = False Then MsgBox ("Íå âûáðàíà ÌÀÐÊÀ!") Exit Sub End If End Sub Sub ramka(stroke) Min = SpinBMin.Value Max = SpinBMax.Value god = CboGod.Text If optbDollar = True Then file1 = " Àâòîìîáèëè ñòîèìîñòüþ îò " & Min & "$ äî " & Max & "$.xls" End If If optbEvro = True Then file1 = "Àâòîìîáèëè ñòîèìîñòüþ îò " & Min & "ˆ äî " & Max & "ˆ.xls" End If Range("C1:R1").Select ActiveCell.FormulaR1C1 = file1 With ActiveCell.Characters(Start:=1, Length:=60).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 12 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("E2", "P2").Select ActiveCell.FormulaR1C1 = "Ãîä âûïóñêà" + god With ActiveCell.Characters(Start:=1, Length:=18).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 12 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("A3").Select ActiveCell.FormulaR1C1 = "Ìàðêà Àâòîìîáèëÿ" With ActiveCell.Characters(Start:=1, Length:=16).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Rows("3:3").Select Selection.RowHeight = 90.75 Range("A3").Select With Selection .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .WrapText = True .Orientation = 0 .AddIndent = False .IndentLevel = 0 .ShrinkToFit = False .ReadingOrder = xlContext .MergeCells = False End With Columns("A:A").ColumnWidth = 15 Selection.Copy Range("A3:E3").Select Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _ SkipBlanks:=False, Transpose:=False Range("E3").Select Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _ SkipBlanks:=False, Transpose:=False Application.CutCopyMode = False Range("B3").Select ActiveCell.FormulaR1C1 = "Ìîäåëü àâòîìîáèëÿ" With ActiveCell.Characters(Start:=1, Length:=23).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("C3").Select Columns("C:C").ColumnWidth = 11.14 Columns("B:B").ColumnWidth = 11.43 Range("C3").Select ActiveCell.FormulaR1C1 = "Öåíà" With ActiveCell.Characters(Start:=1, Length:=4).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("D3").Select ActiveCell.FormulaR1C1 = "Òèï êóçîâà äâåðåé/ìåñò" With ActiveCell.Characters(Start:=1, Length:=22).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Selection.Cut Destination:=Range("E3") Range("E3").Select Selection.Cut Destination:=Range("D3") Range("D3").Select Columns("D:D").ColumnWidth = 10.43 Columns("D:D").ColumnWidth = 12 Range("E3").Select With Selection .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .WrapText = True .Orientation = 0 .AddIndent = False .ShrinkToFit = False .ReadingOrder = xlContext .MergeCells = False End With ActiveCell.FormulaR1C1 = "Ãîä âûïóñêà" With ActiveCell.Characters(Start:=1, Length:=11).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("F3").Select With Selection .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .WrapText = True .Orientation = 0 .AddIndent = False .ShrinkToFit = False .ReadingOrder = xlContext .MergeCells = False End With ActiveCell.FormulaR1C1 = "Öåíòð çàìîê" With ActiveCell.Characters(Start:=1, Length:=11).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("F3").Select With Selection .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .WrapText = True .Orientation = 90 .AddIndent = False .IndentLevel = 0 .ShrinkToFit = False .ReadingOrder = xlContext .MergeCells = False End With Selection.Copy Range("F3:S3").Select Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _ SkipBlanks:=False, Transpose:=False Application.CutCopyMode = False ActiveWindow.ScrollColumn = 5 ActiveWindow.ScrollColumn = 4 ActiveWindow.ScrollColumn = 3 ActiveWindow.ScrollColumn = 2 ActiveWindow.ScrollColumn = 1 Range("G3").Select ActiveCell.FormulaR1C1 = "Ïðîòèâîóãîí Ñèãíàë" With ActiveCell.Characters(Start:=1, Length:=18).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("H3").Select ActiveCell.FormulaR1C1 = "Èììîáèëàéçåð" With ActiveCell.Characters(Start:=1, Length:=12).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("I3").Select ActiveCell.FormulaR1C1 = "Ãèäðîóñèëèòþðóëÿ" With ActiveCell.Characters(Start:=1, Length:=16).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("J3").Select ActiveCell.FormulaR1C1 = "Ðåãóë. Ðóë. Êîëîíêà" With ActiveCell.Characters(Start:=1, Length:=19).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("K3").Select ActiveCell.FormulaR1C1 = "àâòîìàòè÷.ÊÏ" With ActiveCell.Characters(Start:=1, Length:=12).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("L3").Select ActiveCell.FormulaR1C1 = "Ýë.ïðèâîä çåðêàëà" With ActiveCell.Characters(Start:=1, Length:=17).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("M3").Select ActiveCell.FormulaR1C1 = "Ýë.ïðèâîä ñòåêîë" With ActiveCell.Characters(Start:=1, Length:=16).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("N3").Select ActiveCell.FormulaR1C1 = "ýë.ïðèâîä êðåñåë" With ActiveCell.Characters(Start:=1, Length:=16).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("O3").Select ActiveCell.FormulaR1C1 = "Ïîäîãðåâ çåðêàë" With ActiveCell.Characters(Start:=1, Length:=15).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("P3").Select ActiveCell.FormulaR1C1 = "ïîäîãðåâ êðåñåë" With ActiveCell.Characters(Start:=1, Length:=15).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("Q3").Select ActiveCell.FormulaR1C1 = "ïîäóøêè áåçîïàñíîñòè" With ActiveCell.Characters(Start:=1, Length:=20).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("R3").Select ActiveCell.FormulaR1C1 = "ÀÁÑ" With ActiveCell.Characters(Start:=1, Length:=3).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("S3").Select ActiveCell.FormulaR1C1 = "Ôèðìà-ïðîäàâåö" With ActiveCell.Characters(Start:=1, Length:=14).Font .Name = "Arial Cyr" .FontStyle = "ïîëóæèðíûé" .Size = 10 .Strikethrough = False .Superscript = False .Subscript = False .OutlineFont = False .Shadow = False .Underline = xlUnderlineStyleNone .ColorIndex = xlAutomatic End With Range("A3:S3").Select Selection.Borders(xlDiagonalDown).LineStyle = xlNone Selection.Borders(xlDiagonalUp).LineStyle = xlNone With Selection.Borders(xlEdgeLeft) .LineStyle = xlContinuous .Weight = xlThick .ColorIndex = xlAutomatic End With With Selection.Borders(xlEdgeTop) .LineStyle = xlContinuous .Weight = xlThick .ColorIndex = xlAutomatic End With With Selection.Borders(xlEdgeBottom) .LineStyle = xlContinuous .Weight = xlThick .ColorIndex = xlAutomatic End With With Selection.Borders(xlEdgeRight) .LineStyle = xlContinuous .Weight = xlThick .ColorIndex = xlAutomatic End With With Selection.Borders(xlInsideVertical) .LineStyle = xlContinuous .Weight = xlThin .ColorIndex = xlAutomatic End With Selection.AutoFilter Range("L3").Select ActiveWindow.ScrollColumn = 11 ActiveWindow.ScrollColumn = 10 ActiveWindow.ScrollColumn = 9 ActiveWindow.ScrollColumn = 8 ActiveWindow.ScrollColumn = 7 ActiveWindow.ScrollColumn = 6 ActiveWindow.ScrollColumn = 5 ActiveWindow.ScrollColumn = 4 ActiveWindow.ScrollColumn = 3 ActiveWindow.ScrollColumn = 2 ActiveWindow.ScrollColumn = 1 Columns("F:F").ColumnWidth = 3.5 Columns("G:G").ColumnWidth = 3.5 Columns("H:H").ColumnWidth = 3.5 Columns("I:I").ColumnWidth = 3.5 Columns("J:J").ColumnWidth = 3.5 Columns("K:K").ColumnWidth = 3.5 Columns("L:L").ColumnWidth = 3.5 Columns("M:M").ColumnWidth = 3.5 Columns("N:N").ColumnWidth = 3.5 Columns("O:O").ColumnWidth = 3.5 Columns("P:P").ColumnWidth = 3.5 Columns("Q:Q").ColumnWidth = 3.5 Columns("R:R").ColumnWidth = 3.5 Columns("S:S").ColumnWidth = 26.43 Columns("E:E").ColumnWidth = 5 Columns("B:B").ColumnWidth = 20.43 Range("A4").Select End Sub Private Sub LstMarka_Change() If LstMarka.Selected(0) = True Then For i = 1 To LstMarka.ListCount - 1 If LstMarka.Selected(i) = True Then LstMarka.Selected(i) = False End If Next i Exit Sub End If End Sub Private Sub optbDollar_Click() End Sub Private Sub optbEvro_Click() End Sub Private Sub SpinBMax_Change() FrmModel.TextMax.Value = SpinBMax.Value End Sub Private Sub SpinBMin_Change() FrmModel.TextMin.Value = SpinBMin.Value End Sub Private Sub UserForm_Click() End Sub ... |
| 18.09.2006, 14:58:42 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2184270]: |
62ms |
42ms |
| others: | 244ms |
| total: | 404ms |
