сравнение
сравнение книг авторI have to check the contents of a large spreadsheet against a second more up to date spreadsheet in another workbook. The structure of the 2 workbooks is the same. How can I identify which cells differ so I can investigate those individually. This procedure creates a new workbook which lists the comparison results for each worksheet in the two workbooks of interest. Each of the two workbooks should be open prior to running this procedure. Replace the dummy names in the the DoCompare sub with appropriate filenames. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. ... |
| 07.07.2006, 18:15:45 |
сравнение
http://nezavisim.com/?cat=2&scat=8 - бесплатная утилита для сравнения книг экселя. ... |
| 31.07.2006, 23:25:20 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2183769]: |
29ms |
29ms |
| others: | 238ms |
| total: | 328ms |
