шрифт в условном форматировании
условное форматирование не могу поменять размер шрифта в чем может быть проблема? ... |
| 08.02.2007, 12:14:53 |
Use the Font, Border, and Interior properties of the FormatCondition object to control the appearance of formatted cells. Some properties of these objects aren’t supported by the conditional format object model. The properties that can be used with conditional formatting are listed in the following table. Object Properties Font Bold Color ColorIndex FontStyle Italic Strikethrough Underline ... |
| 08.02.2007, 12:28:34 |
start [/forum/search_topic.php?author=%D0%9F%D0%B0%D1%88%D0%B02&author_mode=last_posts&do_search=1]: |
66ms |
42ms |
| others: | 15536ms |
| total: | 15967ms |
