Перебор путей в ориентированном графе
Не примите за спам. Встречал много вопросов в интернете про перебор путей в графе, не нашел сделанных примеров, сделал сам, решил поделиться. Наверняка кому-нибудь пригодится. Не претендую на изысканность кода, зато работает. Public Function sBin$(Source) Dim StrBin As String, lValue As Double If Source < 0 Then lValue = (Source And &H7FFF) Or &H8000& Else: lValue = Source End If Do While lValue > 0 StrBin = Chr((lValue Mod 2) + 48) + StrBin lValue = lValue \ 2 Loop If StrBin = "" Then sBin = "0" Else sBin = StrBin End Function Function min(i, j) As Long If i > j Then min = j Else min = i min = min - 1 If min <= 0 Then min = 1 End Function Sub graf() nn = 13 ' kol-vo vershin v grafe Dim i, j As Integer For i = 1 To 100 For j = 1 To 100 Cells(i, j) = "" Next Next For i = 13 To 1000 Cells(i, 1) = "" Next i Cells(1, 2) = 1 'opisanie grafa, 1-rebro est' , "" - rebra net Cells(2, 3) = 1 Cells(2, 4) = 1 Cells(3, 5) = 1 Cells(4, 5) = 1 Cells(5, 6) = 1 Cells(6, 7) = 1 Cells(7, 8) = 1 Cells(8, 4) = 1 Cells(8, 9) = 1 Cells(9, 10) = 1 Cells(10, 4) = 1 Cells(6, 11) = 1 Cells(9, 12) = 1 Cells(12, 13) = 1 Cells(13, 10) = 1 Cells(12, 10) = 1 Dim konec(1 To 10) As Long konec(1) = 11 ' tochka vyxoda - konechnyi pyt' Dim summa(1 To 200) As Long Dim dopusk(1 To 200) As Long Dim dopusk_point(1 To 200) As Long For i = 1 To nn For j = 1 To nn If Cells(i, j) = 1 Then summa(i) = summa(i) + 1 Next j Next i For i = 1 To nn For j = 1 To nn If Cells(i, j) = 1 Then dopusk(j) = dopusk(j) + 1 Next j Next i For i = 1 To nn dopusk_point(i) = dopusk_point(i) + dopusk(i) Next i For i = 1 To nn For j = 1 To nn If Cells(i, j) = 1 Then dopusk_point(j) = dopusk_point(j) + dopusk(i) End If Next j Next i Dim point(1 To 200) As Long Dim cicle(1 To 200, 1 To 100) As Long Dim path(1 To 10000000) As String Dim g(1 To 200, 1 To 200, 1 To 2) As Long Dim metka(1 To 200, 1 To 200) As Long Dim kkk As String Dim st As String Dim kolvo_reber As Long '========================== For i = 1 To nn For j = 1 To nn If Cells(i, j) = "1" Then g(i, j, 1) = CLng(Cells(i, j)) If summa(i) > 1 Then kolvo_reber = kolvo_reber + 1 g(i, j, 2) = kolvo_reber End If Else g(i, j, 1) = 0 End If Next j Next i '===================== Dim p As Long Dim all As Long all = 2 ^ kolvo_reber - 1 For p = 1 To all ' p=1 - tochka vxoda sBin$(LTrim(Str(2 ^ (nn) - 1))) st = "1" kkk = sBin$(LTrim(Str(p))) Erase metka Erase cicle again: If Len(kkk) < Len(sBin$(LTrim(Str(all)))) Then kkk = "0" + kkk GoTo again End If For i = 1 To nn For j = 1 To nn If g(i, j, 1) = 1 Then If summa(i) > 1 Then If Mid(kkk, g(i, j, 2), 1) = 1 Then metka(i, j) = 1 Else metka(i, j) = 0 ' 0- rebra net, 1 - rebro est' End If Else If summa(i) = 1 Then metka(i, j) = 1 End If End If Next j Next i vershina = 1 marker = 0 Erase cicle Erase point For i = vershina To nn If i > 1 And putt = 0 Then Exit For For j = 2 To nn putt = 0 If g(i, j, 1) = 1 And metka(i, j) = 1 Then If summa(i) > 1 Then marker = i temp = st End If If cicle(i, j) < min(dopusk_point(i), dopusk_point(j)) Then st = st + "->" + LTrim(Str(j)) cicle(i, j) = cicle(i, j) + 1 point(i) = point(i) + 1 If cicle(i, j) > min(dopusk_point(i), dopusk_point(j)) Then 'If summa(i) > 1 Then cicle(j) = cicle(j) - 1 If point(i) > dopusk_point(i) Then i = marker - 1 putt = 1 st = temp Exit For End If End If putt = 1 vershina = j i = vershina - 1 For kon = 1 To 10 If konec(kon) = 0 Then Exit For If konec(kon) = j Then ' konechnaya vershina num_path = num_path + 1 path(num_path) = st 'path finded GoTo next_path End If Next kon Exit For End If End If Next j Next i next_path: Next p For i = 1 To num_path trigger = 0 For j = i + 1 To num_path If path(i) = path(j) Then trigger = 1 Exit For End If Next j If trigger = 0 Then ddd = ddd + 1 Cells(nn + 10 + ddd, 1) = path(i) End If Next i End Sub ... |
| 06.04.2009, 10:23:37 |
К алгоритмам перебора полезно прибавлять расчет вычислительной сложности АЛГОРИТМА. Имеется ввиду, с какой скоростью растет время вычисления в зависимости от размеров графа. И просто из любопытства, учтены ли возможные циклы, отсутствие пути и считаются ли длины путей? Или просто это реализация переборов в глубину / ширину? ... |
| 07.04.2009, 15:44:54 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2179623]: |
174ms |
34ms |
| others: | 219ms |
| total: | 474ms |
