Как подсчитать с активным фильтром ?
есть произвольная функция, подводящая итог (например количество заполненных ячеек) в конце с активным фильтром. Как сделать чтобы в конце я мог выставить произвольную функцию для рассчета столбца, а не только ПРОМЕЖУТОЧНЫЕ.ИТОГИ , для суммы ? ... |
| 23.04.2009, 16:24:41 |
Returns a subtotal in a list or database. It is generally easier to create a list with subtotals using the Subtotals command (Data menu). Once the subtotal list is created, you can modify it by editing the SUBTOTAL function. Syntax SUBTOTAL(function_num, ref1, ref2, ...) Function_num is the number 1 to 11 (includes hidden values) or 101 to 111 (ignores hidden values) that specifies which function to use in calculating subtotals within a list. Function_num (includes hidden values) Function_num (ignores hidden values) Function 1 101 AVERAGE 2 102 COUNT 3 103 COUNTA 4 104 MAX 5 105 MIN 6 106 PRODUCT 7 107 STDEV 8 108 STDEVP 9 109 SUM 10 110 VAR 11 111 VARP Ref1, ref2 are 1 to 29 ranges or references for which you want the subtotal. Remarks If there are other subtotals within ref1, ref2,… (or nested subtotals), these nested subtotals are ignored to avoid double counting. For the function_num constants from 1 to 11, the SUBTOTAL function includes the values of rows hidden by the Hide command under the Row submenu of the Format menu). Use these constants when you want to subtotal hidden and nonhidden numbers in a list. For the function_Num constants from 101 to 111, the SUBTOTAL function ignores values of rows hidden by the Hide command under the Row submenu of the Format menu). Use these constants when you want to subtotal only nonhidden numbers in a list. The SUBTOTAL function ignores any rows that are not included in the result of a filter, no matter which function_num value you use. The SUBTOTAL function is designed for columns of data, or vertical ranges. It is not designed for rows of data, or horizontal ranges. For example, when you subtotal a horizontal range using a function_num of 101 or greater, such as SUBTOTAL(109,B2:G2), hiding a column does not affect the subtotal. But, hiding a row in a subtotal of a vertical range does affect the subtotal. If any of the references are 3-D references, SUBTOTAL returns the #VALUE! error value. ... |
| 23.04.2009, 17:05:24 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2179546]: |
174ms |
39ms |
| others: | 191ms |
| total: | 440ms |
