numbered paragraphs from Word to Excel
there are paragraphs in word 1.doc: 1. text 1.1. text ... 20.text 20.1. text 20.1.1. text .... numbers of points to convert and excel no text 1.xls: 1. 1.1. ... 20. 20.1. 20.1.1. thank you. ... |
| 08.12.2017, 18:23:22 |
>and excel In excel ... |
| 08.12.2017, 18:45:36 |
Amiri, can you attach an example in Word & Excel? Where should the code run from - Word, Excel, vbs? ... |
| 08.12.2017, 20:01:14 |
КазанскийAmiri, can you attach an example in Word & Excel? Where should the code run from - Word, Excel, vbs? sorry here is an example ... |
| 08.12.2017, 20:49:40 |
in excel A B ------ 1 | ------ 1.1 | ------ 1.1.1| ... |
| 08.12.2017, 20:53:37 |
I think to do so, save the word to txt file, remove the text leaving only the numbers. replace a character by another character for example · 183 267 B7. import Excel ... |
| 08.12.2017, 21:06:54 |
crazy method. just to a head more comes nothing. replace in excel different characters on the dot. ... |
| 08.12.2017, 21:14:50 |
fu* up best practice ( ... |
| 08.12.2017, 21:18:29 |
Amiri, try this in Word. Excel must be running, the code will create a new workbook and place text there. Код: vbnet 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. ... |
| 08.12.2017, 22:19:19 |
КазанскийAmiri, try this in Word. Excel must be running, the code will create a new workbook and place text there. Код: vbnet 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. it really works ) thank. and you can remove all the text leaving only the numbers. there is a very large document points to 1.1.1 and to 500.43.1 best practices in dog f1n(dot)in (contact f u in case) ... |
| 08.12.2017, 23:42:48 |
start [/forum/topic.php?fid=61&gotonew=1&tid=2172462]: |
29ms |
76ms |
107ms |
| others: | 308ms |
| total: | 598ms |
