интеграция Apache2 и Tomcat с помощью JK2
При интеграции Apache2 и Tomcat с помощью JK2 уже при старте Apache в журннальном файле Apache - error.log выползают следующие сообщения с ошибкой. Подскажите, в чем тут дело ? =========================================================== [Fri May 23 18:08:19 2003] [notice] Parent: Created child process 516 [Fri May 23 18:08:19 2003] [notice] Child 516: Child process is running [Fri May 23 18:08:19 2003] [notice] jk2_init() Found child 516 in scoreboard slot 0 [Fri May 23 18:08:19 2003] [notice] workerEnv.init() ok D:/Apache2/conf/workers2.properties [Fri May 23 18:08:19 2003] [error] mod_jk child init 1 0 [Fri May 23 18:08:19 2003] [notice] Child 516: Acquired the start mutex. [Fri May 23 18:08:19 2003] [notice] Child 516: Starting 250 worker threads. =++++++++++++++++++++++++++++++++++++++++++++++ # Загрузка mod_jk в файле httpd.conf # LoadModule jk2_module modules\mod_jk2-2.0.43.dll ================================================= Файл workers2.properties имеет следуюший вид ================================================= [logger.apache2] level=DEBUG [shm] file=D:\Apache2\logs\shm.file size=1048576 # Example socket channel, override port and host. [channel.socket:localhost:8009] info=Ajp13 forwarding over socket port=8009 host=127.0.0.1 # define the worker [ajp13:localhost:8009] channel=channel.socket:localhost:8009 # Uri mapping [uri:192.168.210.124/*.jsp] group=ajp13:localhost:8009 [uri:www.booser.it/*.jsp] group=ajp13:localhost:8009 [uri:/examples/*] group=ajp13:localhost:8009 info=Map the whole webapp ========================== ... |
| 24.05.2003, 21:02:53 |
Poprobuy na tomcatovskom forume http://www.mail-archive.com/tomcat-user@jakarta.apache.org/ Also, GIYF (Google is your friend) http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=%5Berror%5D+mod_jk+child+init+1+0+&btnG=Google+Search Yspexov. JJ ... |
| 24.05.2003, 21:48:51 |
JJ спасибо за ссылки ! Я там изрядно покопался. Однако выяснил сам, что и с такой ошибкой все работает, если использовать более старую версию Tomcat. Все задышало. А что там была за проблема я так и не выяснил. ... |
| 04.06.2003, 15:26:55 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2154652]: |
26ms |
56ms |
25ms |
97ms |
| others: | 313ms |
| total: | 578ms |
