диалог
в чем разница между JOptionPane.showMessageDialog( null ,mes,title,JOptionPane.INFORMATION_MESSAGE); и JOptionPane.showMessageDialog( this ,mes,title,JOptionPane.INFORMATION_MESSAGE); и за что отвечает этот параметр ... |
| 03.05.2004, 15:41:57 |
диалог
showMessageDialog public static void showMessageDialog(Component parentComponent, Object message, String title, int messageType) throws HeadlessException Brings up a dialog that displays a message using a default icon determined by the messageType parameter. Parameters: parentComponent - determines the Frame in which the dialog is displayed; if null, or if the parentComponent has no Frame, a default Frame is used message - the Object to display title - the title string for the dialog messageType - the type of message to be displayed: ERROR_MESSAGE, INFORMATION_MESSAGE, WARNING_MESSAGE, QUESTION_MESSAGE, or PLAIN_MESSAGE Throws: HeadlessException - if GraphicsEnvironment.isHeadless returns true See Also: GraphicsEnvironment.isHeadless() ... |
| 04.05.2004, 15:00:28 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2154152]: |
79ms |
79ms |
| others: | 289ms |
| total: | 536ms |
