Что такое webStart?
Что такое webStart? ... |
| 26.11.2004, 11:03:04 |
Что такое webStart?
Using Java Web Start technology, standalone Java software applications can be deployed with a single click over the network. Java Web Start ensures the most current version of the application will be deployed, as well as the correct version of the Java Runtime Environment (JRE) http://java.sun.com/products/javawebstart/overview.html ... |
| 26.11.2004, 11:11:26 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2153378]: |
34ms |
42ms |
| others: | 278ms |
| total: | 411ms |
