services
как сделать чтобы программа работала как сервис ? ... |
| 13.01.2005, 12:15:47 |
services
http://www.google.ru/search?hl=ru&q=java-application+as+nt+service&btnG=%D0%9F%D0%BE%D0%B8%D1%81%D0%BA+%D0%B2+Google&lr= оттуда кое-что: http://www.kcmultimedia.com/javaserv/ http://wrapper.tanukisoftware.org/doc/english/introduction.html -- Lacrima Mosa Est ... |
| 13.01.2005, 12:21:08 |
services
Test.java import java.io.File; import java.io.FileWriter; import java.io.IOException; public class Test { public static void main(String[] arg) throws IOException { File f = new File("log"); f.createNewFile(); FileWriter fw = new FileWriter("log"); fw.write("ok"); fw.close(); } } jsl.ini [service] appname = !!!Test servicename = !!!Test displayname = !!!Test starttype=auto loadordergroup=someorder stopclass=java/lang/System stopmethod=exit stopsignature=(I)V [java] jrepath=d:\java\jdk1.5.0 params = 3 param00 = -cp param01 = c:\downloads\jsl\bin param02 = Test Результат: Error 1053: The service did not respond to the start or control request in a timely fashion ... |
| 13.01.2005, 16:56:13 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2153124]: |
23ms |
52ms |
68ms |
| others: | 298ms |
| total: | 502ms |
