анекдот (почти фак)
Jeroen Wenting Post in the correct place if you expect to get an answer. And pay attention to your spelling, don't demand a rapid response, and generally be nice (so no screaming fits when you don't get the reply you want in 5 minutes (yes, I've seen it happen many times)). As to your statement that your code is perfect: if it were you'd not get an error trying to execute it. Ответ на вопрос "почему моё sturts app не работает???" в форуме посвящённом java certification. ... |
| 10.02.2005, 13:38:05 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2152971]: |
52ms |
68ms |
| others: | 312ms |
| total: | 509ms |
