Проблемы с большими сообщениями в MQ!
Есть код который отправляет в MQ очередь сообщения. Когда кидаю маленькие сообщения не более 1 метра, то все нормально, но когда пытаюсь кмнуть 5 метровое, выскакивает ошибка: [15.02.05 13:55:32:749 NOVT] 17fc17fc ConnectionEve A J2CA0056I: The Connection Manager received a fatal connection error from the Resource Adaptor for resource JMS$mq27$JMSManagedConnection@2042132920. The exception which was received is javax.jms.JMSException: MQJMS2007: failed to send message to MQ queue [15.02.05 13:55:32:812 NOVT] 17fc17fc ConnectionEve A J2CA0056I: The Connection Manager received a fatal connection error from the Resource Adaptor for resource jms/mq27. The exception which was received is javax.jms.JMSException: MQJMS2007: failed to send message to MQ queue [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R Error sending message [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R javax.jms.JMSException: MQJMS2007: failed to send message to MQ queue [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at java.lang.Throwable.<init>(Throwable.java) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at java.lang.Throwable.<init>(Throwable.java) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at javax.jms.JMSException.<init>(JMSException.java:51) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at com.ibm.mq.jms.services.ConfigEnvironment.newException(ConfigEnvironment.java:540) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at com.ibm.mq.jms.MQQueueSender.sendInternal(MQQueueSender.java:824) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at com.ibm.mq.jms.MQQueueSender.send(MQQueueSender.java:239) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at com.ibm.mq.jms.MQQueueSender.send(MQQueueSender.java:272) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at com.ibm.ejs.jms.JMSQueueSenderHandle.send(JMSQueueSenderHandle.java:176) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sender.SenderBean.forward(SenderBean.java:156) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sender.EJSRemoteStatelessSender_36a782e6.forward(EJSRemoteStatelessSender_36a782e6.java:22) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sync.Sender.forward(Sender.java:221) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sync.Dispatch.run(Dispatch.java:109) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sync.SynchronizationBean.dispatch(SynchronizationBean.java:75) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sync.EJSRemoteStatelessSynchronization_ed204a88.dispatch(EJSRemoteStatelessSynchronization_ed204a88.java:22) [15.02.05 13:55:33:062 NOVT] 17fc17fc SystemErr R at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at java.lang.reflect.Method.invoke(Method.java) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at com.ibm.rmi.util.ProxyUtil$4.run(ProxyUtil.java:703) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at java.security.AccessController.doPrivileged(AccessController.java) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at com.ibm.rmi.util.ProxyUtil.invokeWithClassLoaders(ProxyUtil.java:701) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at com.ibm.CORBA.iiop.ClientDelegate.invoke(ClientDelegate.java:1084) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at $Proxy5.dispatch(Unknown Source) [15.02.05 13:55:33:077 NOVT] 17fc17fc SystemErr R at sync._Synchronization_Stub.dispatch(_Synchronization_Stub.java:255) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at java.lang.reflect.Method.invoke(Method.java) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.etools.utc.model.ReflectionMethodModel.invoke(ReflectionMethodModel.java:68) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.etools.utc.servlet.InvokeServlet.invoke(InvokeServlet.java:110) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.etools.utc.servlet.InvokeServlet.doPost(InvokeServlet.java:366) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:760) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.StrictServletInstance.doService(StrictServletInstance.java:110) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.StrictLifecycleServlet._service(StrictLifecycleServlet.java:174) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.IdleServletState.service(StrictLifecycleServlet.java:313) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.StrictLifecycleServlet.service(StrictLifecycleServlet.java:116) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.ServletInstance.service(ServletInstance.java:283) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.ValidServletReferenceState.dispatch(ValidServletReferenceState.java:42) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.servlet.ServletInstanceReference.dispatch(ServletInstanceReference.java:40) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.handleWebAppDispatch(WebAppRequestDispatcher.java:983) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.dispatch(WebAppRequestDispatcher.java:564) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forward(WebAppRequestDispatcher.java:200) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.srt.WebAppInvoker.doForward(WebAppInvoker.java:119) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.srt.WebAppInvoker.handleInvocationHook(WebAppInvoker.java:276) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.cache.invocation.CachedInvocation.handleInvocation(CachedInvocation.java:71) [15.02.05 13:55:33:093 NOVT] 17fc17fc SystemErr R at com.ibm.ws.webcontainer.srp.ServletRequestProcessor.dispatchByURI(ServletRequestProcessor.java:182) Как побороть ошибку? И вообще из-за чего она? ... |
| 16.02.2005, 13:03:33 |
в фидо не помогли? :) -- Lacrima Mosa Est ... |
| 16.02.2005, 13:21:12 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2152944]: |
43ms |
54ms |
| others: | 318ms |
| total: | 475ms |
