progressBar.setIndeterminate(true);
Помогите пжлс разобраться, почему ошибка! public void actionPerformed(ActionEvent e) { new ProgressFrame(MyFrame,"Wait ...",new Runnable() {public void run() { try { //Code }catch(Exception e){ System.out.Println("Error?!!!-1"); } } }); } -------------------------------------------------------------- public class ProgressFrame { JDialog progressDialog; Thread thread; public ProgressFrame(JFrame parent, String title, final Runnable task) { progressDialog = new JDialog(parent, title, true); final JProgressBar progressBar = new JProgressBar(); progressBar.setIndeterminate(true); JPanel panel = new JPanel(); //... panel.add(progressBar); progressDialog.getContentPane().add(panel); progressDialog.pack(); progressDialog.setSize(300,progressDialog.getHeight()); progressDialog.setResizable(false); thread = new Thread() { public void run() { try { task.run(); progressDialog.dispose(); } catch (Exception e) { System.out.Println("Error?!!!-2"); } } }; thread.start(); try{ progressDialog.show(); }catch (Exception e){ System.out.Println("Error?!!!-3"); } } } Exception occurred during event dispatching: java.lang.NullPointerException at javax.swing.text.html.BlockView.paint(BlockView.java:263) at javax.swing.plaf.basic.BasicTextUI$RootView.paint(BasicTextUI.java:1319) at javax.swing.plaf.basic.BasicTextUI.paintSafely(BasicTextUI.java:636) at javax.swing.plaf.basic.BasicTextUI.paint(BasicTextUI.java:770) at javax.swing.plaf.basic.BasicTextUI.update(BasicTextUI.java:749) at javax.swing.JComponent.paintComponent(JComponent.java:541) at javax.swing.JComponent.paint(JComponent.java:808) at javax.swing.JComponent.paintWithOffscreenBuffer(JComponent.java:4787) at javax.swing.JComponent.paintDoubleBuffered(JComponent.java:4740) at javax.swing.JComponent._paintImmediately(JComponent.java:4685) at javax.swing.JComponent.paintImmediately(JComponent.java:4488) at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:410) at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:117) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:178) at java.awt.EventQueue.dispatchEvent(EventQueue.java:454) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:141) at java.awt.Dialog$1.run(Dialog.java:540) at java.awt.Dialog.show(Dialog.java:561) at rdfmapper.utils.ProgressFrame.<init>(ProgressFrame.java:76) //public class ProgressFrame {.... at rdfmapper.panelrdf.PanelRDF.actionPerformed(PanelRDF.java:110) //public void actionPerformed(ActionEvent e) {... at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1786) at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(AbstractButton.java:1839) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:245) at java.awt.Component.processMouseEvent(Component.java:5100) at java.awt.Component.processEvent(Component.java:4897) at java.awt.Container.processEvent(Container.java:1569) at java.awt.Component.dispatchEventImpl(Component.java:3615) at java.awt.Container.dispatchEventImpl(Container.java:1627) at java.awt.Component.dispatchEvent(Component.java:3477) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:3483) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3198) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3128) at java.awt.Container.dispatchEventImpl(Container.java:1613) at java.awt.Window.dispatchEventImpl(Window.java:1606) at java.awt.Component.dispatchEvent(Component.java:3477) at java.awt.EventQueue.dispatchEvent(EventQueue.java:456) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:145) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:137) at java.awt.EventDispatchThread.run(EventDispatchThread.java:100) Ошибка выпадает один раз из 3-5. Причем все работает как надо! ... |
| 06.04.2005, 19:06:35 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2152649]: |
23ms |
44ms |
53ms |
| others: | 337ms |
| total: | 515ms |
