struts
Код: plaintext 1. 2. 3. 4. 5. 6. хочу вместо BLABLABLA подставить тоже значение что и в <bean:write name="list" /> ... |
| 26.04.2005, 16:33:08 |
struts
Попробуй: Код: plaintext 1. 2. 3. 4. 5. ... |
| 26.04.2005, 16:50:37 |
struts
можно через аттрибуты, у link-tag есть аттрибуты struts userGuide ... paramId The name of the request parameter that will be dynamically added to the generated hyperlink. The corresponding value is defined by the paramName and (optional) paramProperty attributes, optionally scoped by the paramScope attribute [RT Expr] paramName The name of a JSP bean that is a String containing the value for the request parameter named by paramId (if paramProperty is not specified), or a JSP bean whose property getter is called to return a String (if paramProperty is specified). The JSP bean is constrained to the bean scope specified by the paramScope property, if it is specified. [RT Expr] paramProperty The name of a property of the bean specified by the paramName attribute, whose return value must be a String containing the value of the request parameter (named by the paramId attribute) that will be dynamically added to this hyperlink. ... например: Код: plaintext 1. ... |
| 26.04.2005, 17:15:38 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2152492]: |
27ms |
48ms |
87ms |
| others: | 385ms |
| total: | 620ms |
