Копирование объектов !
Стыдно конечно задавать такой вопрос, но все же... Есть ли в java механизмы копирования объектов? типа этого - object1.assing(object2); ... |
| 21.06.2005, 03:08:23 |
Код: plaintext спрафкаThe method clone for class Object performs a specific cloning operation. First, if the class of this object does not implement the interface Cloneable, then a CloneNotSupportedException is thrown. Note that all arrays are considered to implement the interface Cloneable. Otherwise, this method creates a new instance of the class of this object and initializes all its fields with exactly the contents of the corresponding fields of this object, as if by assignment; the contents of the fields are not themselves cloned. Thus, this method performs a "shallow copy" of this object, not a "deep copy" operation. ... |
| 21.06.2005, 03:51:00 |
спасиба )) ... |
| 21.06.2005, 12:17:54 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2152173]: |
86ms |
79ms |
| others: | 311ms |
| total: | 570ms |
