hibernate
Здравствуйте, я пытаюсь изучить Hibernate по книге "Hibernate: A Developer's Notebook". В связи с этим возникли проблемы (в архиве - иерархия каталогов с файлами): 1. не генерируется схема базы данных: C:\Program Files\Apache Group\Tomcat 4.1\webapps\play>ant schema Buildfile: build.xml prepare: compile: [javac] Compiling 1 source file to C:\Program Files\Apache Group\Tomcat 4.1\ webapps\play\classes schema: [schemaexport] 21:19:30,516 INFO Environment:483 - Hibernate 2.1.8 [schemaexport] 21:19:30,536 INFO Environment:517 - loaded properties from resou rce hibernate.properties: {hibernate.connection.username=sa, hibernate.connectio n.password=, hibernate.cglib.use_reflection_optimizer=true, hibernate.dialect=ne t.sf.hibernate.dialect.HSQLDialect, hibernate.connection.url=jdbc:hsqldb:data/mu sic, hibernate.connection.driver_class=org.hsqldb.jdbcDriver} [schemaexport] 21:19:30,546 INFO Environment:543 - using CGLIB reflection optim izer [schemaexport] 21:19:30,556 INFO Environment:572 - using JDK 1.4 java.sql.Times tamp handling [schemaexport] 21:19:30,576 INFO Configuration:170 - Mapping file: C:\Program F iles\Apache Group\Tomcat 4.1\webapps\play\classes\com\oreilly\hh\Track.hbm.xml [schemaexport] 21:19:31,217 INFO Binder:229 - Mapping class: com.oreilly.hh.Tra ck -> TRACK [schemaexport] 21:19:31,517 INFO Dialect:86 - Using dialect: net.sf.hibernate.d ialect.HSQLDialect [schemaexport] 21:19:31,537 INFO Configuration:641 - processing one-to-many ass ociation mappings [schemaexport] 21:19:31,537 INFO Configuration:650 - processing one-to-one asso ciation property references [schemaexport] 21:19:31,537 INFO Configuration:675 - processing foreign key con straints [schemaexport] 21:19:31,648 INFO Configuration:641 - processing one-to-many ass ociation mappings [schemaexport] 21:19:31,648 INFO Configuration:650 - processing one-to-one asso ciation property references [schemaexport] 21:19:31,648 INFO Configuration:675 - processing foreign key con straints [schemaexport] 21:19:31,668 INFO SchemaExport:98 - Running hbm2ddl schema expor t [schemaexport] 21:19:31,668 INFO SchemaExport:112 - writing generated schema to file: schema-export.sql [schemaexport] 21:19:31,678 INFO SchemaExport:117 - exporting generated schema to database [schemaexport] 21:19:31,698 INFO DriverManagerConnectionProvider:42 - Using Hib ernate built-in connection pool (not for production use!) [schemaexport] 21:19:31,698 INFO DriverManagerConnectionProvider:43 - Hibernate connection pool size: 20 [schemaexport] 21:19:31,708 INFO DriverManagerConnectionProvider:77 - using dri ver: org.hsqldb.jdbcDriver at URL: jdbc:hsqldb:data/music [schemaexport] 21:19:31,718 INFO DriverManagerConnectionProvider:78 - connectio n properties: {user=sa, password=} [schemaexport] drop table TRACK if exists; [schemaexport] 21:19:32,709 DEBUG SchemaExport:132 - drop table TRACK if exists; [schemaexport] create table TRACK ( [schemaexport] TRACK_ID integer generated by default as identity (start with 1), [schemaexport] title varchar(255) not null, [schemaexport] filePath varchar(255) not null, [schemaexport] playTime time, [schemaexport] added date, [schemaexport] volume smallint [schemaexport] ); [schemaexport] 21:19:32,719 DEBUG SchemaExport:149 - create table TRACK ( [schemaexport] TRACK_ID integer generated by default as identity (start with 1), [schemaexport] title varchar(255) not null, [schemaexport] filePath varchar(255) not null, [schemaexport] playTime time, [schemaexport] added date, [schemaexport] volume smallint [schemaexport] ); [schemaexport] 21:19:32,739 INFO SchemaExport:160 - schema export complete [schemaexport] 21:19:32,749 INFO DriverManagerConnectionProvider:143 - cleaning up connection pool: jdbc:hsqldb:data/music BUILD SUCCESSFUL Total time: 9 seconds Насколько я понял, выдаются сообщения, что экспорт схемы прошел успешно, одноко на самом деле таблица в базе данных не создается. Я добавил экспорт скрипта в файл sql, после этого выполнив команды файла в базе все нормально создалось. Понятно, что можно делать все руками, но хотелось бы автоматом. Скажите, где и что я пропустил? 2. не получается ввести данные в таблицу базы: C:\Program Files\Apache Group\Tomcat 4.1\webapps\play>ant ctest Buildfile: build.xml prepare: compile: ctest: [java] 21:25:42,791 INFO Environment:483 - Hibernate 2.1.8 [java] 21:25:42,841 INFO Environment:517 - loaded properties from resource hibernate.properties: {hibernate.connection.username=sa, hibernate.connection.p assword=, hibernate.cglib.use_reflection_optimizer=true, hibernate.dialect=net.s f.hibernate.dialect.HSQLDialect, hibernate.connection.url=jdbc:hsqldb:data/music , hibernate.connection.driver_class=org.hsqldb.jdbcDriver} [java] 21:25:42,841 INFO Environment:543 - using CGLIB reflection optimize r [java] 21:25:42,851 INFO Environment:572 - using JDK 1.4 java.sql.Timestam p handling [java] 21:25:42,851 INFO Configuration:351 - Mapping resource: com/oreilly /hh/Track.hbm.xml [java] 21:25:44,093 INFO Binder:229 - Mapping class: com.oreilly.hh.Track -> TRACK [java] 21:25:44,283 INFO Configuration:641 - processing one-to-many associ ation mappings [java] 21:25:44,283 INFO Configuration:650 - processing one-to-one associa tion property references [java] 21:25:44,283 INFO Configuration:675 - processing foreign key constr aints [java] 21:25:44,344 INFO Dialect:86 - Using dialect: net.sf.hibernate.dial ect.HSQLDialect [java] 21:25:44,364 INFO SettingsFactory:74 - Use outer join fetching: tru e [java] 21:25:44,384 INFO DriverManagerConnectionProvider:42 - Using Hibern ate built-in connection pool (not for production use!) [java] 21:25:44,384 INFO DriverManagerConnectionProvider:43 - Hibernate co nnection pool size: 20 [java] 21:25:44,384 INFO DriverManagerConnectionProvider:77 - using driver : org.hsqldb.jdbcDriver at URL: jdbc:hsqldb:data/music [java] 21:25:44,384 INFO DriverManagerConnectionProvider:78 - connection p roperties: {user=sa, password=} [java] 21:25:44,424 INFO TransactionManagerLookupFactory:33 - No Transacti onManagerLookup configured (in JTA environment, use of process level read-write cache is not recommended) [java] 21:25:45,455 INFO SettingsFactory:114 - Use scrollable result sets: true [java] 21:25:45,465 INFO SettingsFactory:117 - Use JDBC3 getGeneratedKeys( ): false [java] 21:25:45,465 INFO SettingsFactory:120 - Optimize cache for minimal puts: false [java] 21:25:45,465 INFO SettingsFactory:129 - Query language substitution s: {} [java] 21:25:45,465 INFO SettingsFactory:140 - cache provider: net.sf.hibe rnate.cache.EhCacheProvider [java] 21:25:45,485 INFO Configuration:1130 - instantiating and configurin g caches [java] 21:25:45,525 WARN Configurator:125 - No configuration found. Config uring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/C:/Pro gram%20Files/Apache%20Group/Tomcat%204.1/webapps/play/lib/ehcache-0.9.jar!/ehcac he-failsafe.xml [java] 21:25:45,856 INFO SessionFactoryImpl:119 - building session factory [java] 21:25:46,607 INFO SessionFactoryObjectFactory:82 - Not binding fact ory to JNDI, no JNDI name configured [java] 21:25:46,837 INFO SessionFactoryImpl:542 - closing [java] 21:25:46,837 INFO DriverManagerConnectionProvider:143 - cleaning up connection pool: jdbc:hsqldb:data/music BUILD SUCCESSFUL Total time: 7 seconds Опять таки BUILD SUCCESSFUL, но данных в таблицу не добавляется. Подскажите пожалуйста, где я ошибся. Вообще кто-нибудь с hibernate разбирался, можете подсказать с чего лучше начать, может книжку какую посоветуете. ... |
| 20.07.2005, 04:14:20 |
hibernate
на русском языке же есть документация(где-то на половину на русском). Идет, если я не ошибаюсь , вместе с дистрибом. А базу данных можно самому руками сгенерировать, а потом хибернейт на нее натянуть и посмотреть что из этого получится. Имхо пытаться изучить хбернэйт начиная с изучения его тулз по генерации бд и прочего -это подход немного не с той стороны. ... |
| 20.07.2005, 05:54:07 |
hibernate
каким образом можно хибернейт натянуть на существующую базу ? ... |
| 20.07.2005, 09:45:27 |
hibernate
Alexey TurnИмхо пытаться изучить хбернэйт начиная с изучения его тулз по генерации бд и прочего -это подход немного не с той стороны. 1.Возможно я начал и не с той строны, но создав руками таблицу в базе не могу внести в нее данные с помощью hibernate. Уж это-то наверно та самая сторона? Если ты работал с hibernate, можешь объяснить на простом примере, как все завести например с тойже hsqldb или MySQL? ... |
| 21.07.2005, 07:02:35 |
start [/forum/moderation_log.php?user_name=Osya+%28no+russian+keyboard%29]: |
26ms |
61ms |
67ms |
| others: | 661ms |
| total: | 925ms |
