Господа!
Имеется Tomcat+SSL.
Имеется JSP co ссылкой при клике на которую вызывается JavaScript(Календарик). Всё работает нормально.
Но Tomcat матерится таким образом:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
02 . 08 . 2005 13 : 02 : 41 org.apache.tomcat.util.net.PoolTcpEndpoint processSocket
SEVERE: Socket error caused by remote host / 192 . 168 . 5 . 99
java.net.SocketException: Software caused connection abort: recv failed
at java.net.SocketInputStream.socketRead0( Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at com.sun.net.ssl.internal.ssl.InputRecord.readFully(Unknown Source)
at com.sun.net.ssl.internal.ssl.InputRecord.read(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.waitForClose(Unknown Source)
at com.sun.net.ssl.internal.ssl.HandshakeOutStream.flush(Unknown Source)
at com.sun.net.ssl.internal.ssl.Handshaker.sendChangeCipherSpec(Unknown Source)
at com.sun.net.ssl.internal.ssl.ServerHandshaker.sendChangeCipherAndFinish(Unknown Source)
at com.sun.net.ssl.internal.ssl.ServerHandshaker.clientFinished(Unknown Source)
at com.sun.net.ssl.internal.ssl.ServerHandshaker.processMessage(Unknown Source)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Unknown Source)
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at org.apache.tomcat.util.net.jsse.JSSESocketFactory.handshake(JSSESocketFactory.java: 119 )
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java: 520 )
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java: 80 )
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java: 684 )
at java.lang.Thread.run(Unknown Source)
И так всегда при запросе этого скрипта.
И избавиться от этих exceptions?
