Что может быть ?
среда Линух jdk1.3 Oracle 10 Instant client соединение jdbc:oracle:oci:@Alias Unexpected Signal : 11 occurred at PC=0x2192E8 Function name=(N/A) Library=/jdk1.3.1_16/jre/lib/i386/client/libjvm.so NOTE: We are unable to locate the function name symbol for the error just occurred. Please refer to release documentation for possible reason and solutions. Current Java thread: at oracle.jdbc.driver.T2CConnection.t2cGetCharSet(Native Method) at oracle.jdbc.driver.T2CConnection.getCharSetIds(T2CConnection.java:2872) at oracle.jdbc.driver.T2CConnection.logon(T2CConnection.java:302) at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:346) at oracle.jdbc.driver.T2CConnection.<init>(T2CConnection.java:138) at oracle.jdbc.driver.T2CDriverExtension.getConnection(T2CDriverExtension.java:78) at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:549) at java.sql.DriverManager.getConnection(DriverManager.java:512) at java.sql.DriverManager.getConnection(DriverManager.java:141) at com.wm.app.b2b.server.JDBCConnection._doConnect(JDBCConnection.java:349) at com.wm.app.b2b.server.JDBCConnection.<init>(JDBCConnection.java:257) at com.wm.app.b2b.server.DBConnectionManager.getConnection_Session(DBConnectionManager.java:424) at com.wm.app.b2b.server.DBConnectionManager.getConnection(DBConnectionManager.java:216) at pub.db.getConnection(db.java:1016) at pub.db.getTables(db.java:622) at java.lang.reflect.Method.invoke(Native Method) at com.wm.app.b2b.server.JavaService.baseInvoke(JavaService.java:288) at com.wm.app.b2b.server.ServiceManager.invoke(ServiceManager.java:707) at com.wm.app.b2b.server.ServiceManager.invoke(ServiceManager.java:499) at com.wm.app.b2b.server.ns.Namespace.invoke(Namespace.java:452) at com.wm.util.template.Reporter.invoke(Reporter.java:867) at com.wm.util.template.InvokeToken.eval(InvokeToken.java:70) at com.wm.util.template.TemplateToken.evalChild(TemplateToken.java:174) at com.wm.util.template.TemplateToken.eval(TemplateToken.java:143) at com.wm.util.template.Reporter.reportNoReset(Reporter.java:1167) at com.wm.util.template.Reporter.reportToOutput(Reporter.java:1142) at com.wm.util.template.Reporter.reportIData(Reporter.java:1031) at com.wm.app.b2b.server.HTTPDocHandler._process (HTTPDocHandler.java:477) at com.wm.app.b2b.server.HTTPDocHandler.process(HTTPDocHandler.java:109) at com.wm.app.b2b.server.HTTPDispatch.run(HTTPDispatch.java:468) at com.wm.util.pool.PooledThread.run(C:/NT/Perforce/basis/4.1.0-terra/module/core/source/com/wm/util/pool/PooledThread.java:103) at java.lang.Thread.run(Thread.java:479) ... |
| 17.10.2005, 12:35:22 |
Что может быть ?
1) так пробовал? Код: plaintext 1. 2. 3. ... |
| 17.10.2005, 12:39:58 |
Что может быть ?
Какой именно JDBC-драйвер ты используешь? В Oracle10g уже JDK1.4, можно попробовать: - обновить свою локальную JDK; - использовать драйвера для 1.3, из списка драйверов: classes12.jar - for use with JDK 1.2 and JDK 1.3 ojdbc14.jar - classes for use with JDK 1.4 and 1.5 Posted via ActualForum NNTP Server 1.3 ... |
| 17.10.2005, 12:53:27 |
Что может быть ?
Через thin работает. Вот через оси не могу подключится! JDK не могу сменить - на эту версию завязано много! ... |
| 17.10.2005, 13:43:21 |
Что может быть ?
так работай через thin. в чем проблемы? ... |
| 17.10.2005, 13:56:13 |
Что может быть ?
Это приказ начальства !!! Да и еще сама база девятой версии а клиент десятка. Возможна ли из-за этого несовместимость? Хотя по SQL plus соединение проходит! ... |
| 17.10.2005, 14:04:41 |
Что может быть ?
JDBC Developers Guide and Reference Choosing the Appropriate Driver Consider the following when choosing a JDBC driver to use for your application or applet: If you are writing an applet, you must use the JDBC Thin driver. JDBC OCI-based driver classes will not work inside a Web browser, because they call native (C language) methods. If you want maximum portability and performance, use the JDBC Thin driver. You can connect to an Oracle server from either an application or an applet using the JDBC Thin driver. If you are writing a client application for an Oracle client environment and need maximum performance, then choose the JDBC OCI driver. For code that runs in an Oracle server acting as a middle tier, use the server-side Thin driver. If your code will run inside the target Oracle server, then use the JDBC server-side internal driver to access that server. (You can also access remote servers using the server-side Thin driver.) If performance is critical to your application, you want maximum scalability of the Oracle server, or you need the enhanced availability features like TAF or the enhanced proxy features like middle-tier authentication тебе что больше подходит? да, еще вот это запускал? Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. ... |
| 17.10.2005, 14:13:39 |
Что может быть ?
Мне OCI подходит тем что много данных крутить приходится! Я пробовал все предложенные варианты но не получается! Какая то ошибка с чарсетом проходит! ... |
| 17.10.2005, 14:31:01 |
Что может быть ?
at oracle.jdbc.driver.T2CConnection.t2cGetCharSet(Native Method) ... |
| 17.10.2005, 14:33:57 |
Что может быть ?
Есть такая проблема при использовании JDBC от Oracle10.1 при коннекте к 9-й базе: Проблемы с кслиентом Oracle10 Попробуй взять последние драйвера от Oracle 10.2, по-моему там это исправлено. ... |
| 17.10.2005, 14:43:15 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2151214]: |
41ms |
90ms |
| others: | 377ms |
| total: | 603ms |
