Вышел JasperReports 1.0.1
Вышел JasperReports 1.0.1 и iReport 0.5.1 к нему. Change log- further chart element customization possible using a new JRChartCustomizer interface and the "customizerClass" attribute available for charts; - new RTF and plain text exporters added; - new FONT_MAP exporter parameter introduced to allow export-time font mappings and better control of font translation during document export; - support for generating PDF bookmarks from report anchors using a new "bookmarkLever" attribute available for hyperlink elements; - new IS_IGNORE_PAGINATION built-in parameter for disabling pagination and allow creating flow-based documents instead of page-based documents; - minor bug fixes and improvements; Теперь и RTF :) ... |
| 29.08.2005, 10:29:37 |
У кого есть Ultimative Guide v2.0 и вообще доки- поделитесь пожалуйста :) ... |
| 02.09.2005, 15:43:22 |
Есть 1.0. 2.0 в осле не искал? ... |
| 02.09.2005, 15:49:17 |
У меня тоже есть 1.0 - а вот осла нет :( ... |
| 02.09.2005, 19:57:51 |
GMax2.0 в осле не искал? Не нашел в осле :( ... |
| 05.09.2005, 19:17:22 |
Я нашел на каком то варезном сайте но ссылка оказалась битой... ... |
| 06.09.2005, 01:01:16 |
Change logJasperReports 1.1.0 Change Log =================================== - support for report styles that can be referenced by elements to inherit visual properties such as font, color, border, etc; report fonts are now deprecated; - new frame element added to support grouping other report element together; - new dataset concept that comprises parameter, field, variable and group declarations and represents a mixture between a data source and a subreport to help iterating through data for chart and crosstab generation; - support for crosstabs added using a specialized component; - new XLS exporter implementation that uses the Java Excel Api open source library is available as a sample; contributed by Manuel Paul (Rat & Tat Beratungsgesellschaft mbH); - minor bug fixes and improvements; ... |
| 24.10.2005, 08:14:11 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2151159]: |
27ms |
52ms |
86ms |
| others: | 337ms |
| total: | 569ms |
