Помогите с ant
Звучит смешно, но ситуация такова: Мы только начали изучать JAVA и получили такое задание build.xml в указанных строках исправить ошибки эти 3 строки выделены красным . Интересуют только они, но на всякий случай весь файл <!-- Buildfile --> <project name="jake2" default="" basedir="."> <taskdef name="proguard" classname="proguard.ant.ProGuardTask"> <classpath> <pathelement location="lib/proguard/proguard.jar"/> </classpath> </taskdef> <taskdef name="izpack" classpath="lib/izpack/standalone-compiler.jar" classname="com.izforge.izpack.ant.IzPackTask"/> <!-- properties --> <property name="version" value="0.9.4"/> <property name="src" location="src"/> <property name="patch" location="patch"/> <property name="test" location="test"/> <property name="build" location="build"/> <property name="dist" location="dist"/> <!-- different classpaths --> <path id="build.class.path"> <pathelement location="lib/jogl/jogl.jar"/> <pathelement location="lib/joal/linux/joal.jar"/> <pathelement location="lib/lwjgl/lwjgl.jar"/> <pathelement location="lib/lwjgl/lwjgl_util.jar"/> </path> <!-- usage --> <target name="usage"> <echo message="command line arguments for build.sh or build.bat"/> <echo message=""/> <echo message="installer build installer"/> <echo message="bindist build .tar.gz and .zip binary distribution"/> <echo message="srcdist build only source distribution"/> <echo message="all build everything"/> <echo message="clean delete classfiles keep distribution files"/> <echo message="distclean delete all generated files"/> <echo message="jar build only dist/lib/jake2.jar"/> <echo message=""/> </target> <!-- initialize directories --> <target name="init"> <mkdir dir="${build}"/> <mkdir dir="${dist}/lib"/> </target> <!-- compile --> <target name="compile" depends=""> <javac destdir="${build}" optimize="on" debug="off" source="1.4"> <src path="${src}"/> <include name="jake2/**"/> <classpath refid="build.class.path"/> </javac> </target> <!-- copy resources --> <target name="copyres" depends="init"> <copy todir="${build}"> <fileset dir="resources"> <include name="**/*"/> </fileset> </copy> </target> <!-- copy files --> <target name="copy"> <copy todir="${dist}/lib"> <fileset dir="lib/jogl"> <include name="*.jar"/> </fileset> <fileset dir="lib/lwjgl"> <include name="*.jar"/> </fileset> </copy> <copy todir="${dist}/lib/linux"> <fileset dir="lib/jogl/linux"> <include name="*"/> </fileset> <fileset dir="lib/joal/linux"> <include name="*"/> </fileset> </copy> <copy todir="${dist}/lib/linux/lwjgl"> <fileset dir="lib/lwjgl/linux"> <include name="*"/> </fileset> </copy> <copy todir="${dist}/lib/windows"> <fileset dir="lib/jogl/windows"> <include name="*"/> </fileset> <fileset dir="lib/joal/windows"> <include name="*"/> </fileset> <fileset dir="lib/lwjgl/windows"> <include name="*"/> </fileset> </copy> <copy todir="${dist}/lib/osx"> <fileset dir="lib/jogl/osx"> <include name="*"/> </fileset> <fileset dir="lib/joal/osx"> <include name="*"/> </fileset> <fileset dir="lib/lwjgl/osx"> <include name="*"/> </fileset> </copy> <copy todir="${dist}"> <fileset dir="scripts"> <include name="Jake2*"/> </fileset> <fileset dir="."> <include name="ChangeLog"/> <include name="LICENSE"/> <include name="README"/> <include name="readme.id"/> </fileset> </copy> <chmod perm="755"> <fileset dir="${dist}"> <include name="*.sh"/> </fileset> </chmod> <fixcrlf srcdir="${dist}" eol="crlf" includes="*.bat" /> <fixcrlf srcdir="${dist}" eol="lf" includes="*.sh" /> </target> <!-- jar --> <target name="jar" depends="compile,copyres"> <jar destfile="jake2.jar" basedir="${build}"> <include name="jake2/**"/> <include name="*.png"/> <include name="mirrors"/> </jar> <proguard printseeds="on" printusage="off" outjar="${dist}/lib/jake2.jar" defaultpackage="" overloadaggressively="off" printmapping="jake2.map"> <injar name="jake2.jar"/> <libraryjar name="lib/jogl/jogl.jar"/> <libraryjar name="lib/joal/linux/joal.jar"/> <libraryjar name="${java.home}/lib/rt.jar"/> <keep access="public" name="jake2.Jake2"> <method name="main(java.lang.String[])"/> </keep> </proguard> </target> <!-- everything --> <target name="all" depends=""> </target> <!-- dist --> <target name="dist" depends="jar,copy"> </target> <!-- binary distribution --> <target name="bindist" depends="dist"> <tar destfile="jake2-${version}.tar.gz" compression="gzip"> <tarfileset dir="${dist}" prefix="Jake2" mode="755"> <include name="*.sh"/> </tarfileset> <tarfileset dir="${dist}" prefix="Jake2"> <include name="**"/> <exclude name="*.sh"/> </tarfileset> </tar> <zip destfile="jake2-${version}.zip"> <zipfileset dir="${dist}" prefix="Jake2"> <include name="**"/> </zipfileset> </zip> </target> <!-- source distribution --> <target name="srcdist"> <tar destfile="jake2src-${version}.tar.gz" compression="gzip"> <tarfileset dir="." prefix="Jake2" mode="755"> <include name="scripts/*.*"/> <include name="build.sh"/> </tarfileset> <tarfileset dir="." prefix="Jake2"> <include name="src/jake2/**"/> <include name="patch/**"/> <include name="resources/**"/> <include name="lib/**"/> <include name="build.xml"/> <include name="build.bat"/> <include name="ChangeLog"/> <include name="LICENSE"/> <include name="README*"/> <include name="install.xml"/> <include name="readme.id"/> </tarfileset> </tar> <zip destfile="jake2src-${version}.zip"> <zipfileset dir="." prefix="Jake2"> <include name="src/jake2/**"/> <include name="patch/**"/> <include name="resources/**"/> <include name="scripts/*.*"/> <include name="lib/**"/> <include name="build.xml"/> <include name="build.sh"/> <include name="build.bat"/> <include name="ChangeLog"/> <include name="LICENSE"/> <include name="README*"/> <include name="install.xml"/> <include name="readme.id"/> </zipfileset> </zip> </target> <!-- standalone installer --> <target name="installer" depends="dist"> <izpack input="${basedir}/install.xml" output="${basedir}/Jake2-${version}-install.jar" installerType="standard" basedir="${dist}" izPackDir="${basedir}/lib/izpack"/> </target> <!-- webstart --> <target name="webstart" depends="dist,patch"> <mkdir dir="webstart/lib"/> <copy todir="webstart/lib"> <fileset dir="${dist}/lib"> <include name="**/*.jar"/> <exclude name="jake2.jar"/> <exclude name="jogl.jar"/> </fileset> <fileset dir="."> <include name="patch.jar"/> <include name="jake2.jar"/> </fileset> </copy> <jar destfile="webstart/lib/linux/joal-native.jar" basedir="${dist}/lib/linux"> <include name="libjoal.so"/> </jar> <jar destfile="webstart/lib/linux/lwjgl-native.jar" basedir="${dist}/lib/linux/lwjgl"> <include name="*.so"/> </jar> <jar destfile="webstart/lib/linux/openal.jar" basedir="${dist}/lib/linux"> <include name="libopenal.so"/> </jar> <jar destfile="webstart/lib/osx/joal-native.jar" basedir="${dist}/lib/osx"> <include name="libjoal.jnilib"/> </jar> <jar destfile="webstart/lib/osx/lwjgl-native.jar" basedir="${dist}/lib/osx"> <include name="liblwjgl.jnilib"/> <include name="openal.dylib"/> </jar> <jar destfile="webstart/lib/windows/joal-native.jar" basedir="${dist}/lib/windows"> <include name="joal.dll"/> <include name="OpenAL32.dll"/> </jar> <jar destfile="webstart/lib/windows/lwjgl-native.jar" basedir="${dist}/lib/windows"> <include name="lwjgl.dll"/> <include name="lwjglaudio.dll"/> </jar> <signjar keystore="${user.home}/bytonic" alias="bytonic" storepass="${bytonic.pass}"> <fileset dir="webstart/lib"> <include name="**/*.jar"/> </fileset> </signjar> </target> <!-- clean --> <target name="clean"> <delete dir="${build}"/> </target> <!-- distclean --> <target name="distclean" depends="clean"> <delete dir="${dist}"/> <delete dir="webstart/lib"/> <delete> <fileset dir="."> <include name="*.tar.gz"/> <include name="*.zip"/> <include name="*.map"/> <include name="*.jar"/> </fileset> </delete> </target> <!-- patch --> <target name="patch"> <javac destdir="${build}" optimize="on" debug="off" source="1.4"> <src path="${patch}"/> <include name="**"/> <classpath refid="build.class.path"/> </javac> <jar destfile="patch.jar" basedir="${build}"> <include name="net/**"/> </jar> </target> </project> Моих сегодняшних знаний не хватит даже на то, чтобы понять для чего этот файл вообще нужен. Посмотрев на примеры в Интернете и на сайте, думаю они должны так выглядеть 1. <project name="jake2" default="usage" basedir="."> 2. <target name="compile" depends="init"> 3. <target name="all" depends="jar, copy"> Кто разбирается подскажите так это или нет, речь идет о зачете ... |
| 03.01.2006, 02:33:55 |
Помогите с ant
http://cvs.sourceforge.net/viewcvs.py/*checkout*/jake2/jake2/build.xml По крайней мере так он выглядит в оригинале :) ... |
| 03.01.2006, 12:06:13 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2150540]: |
25ms |
69ms |
65ms |
| others: | 402ms |
| total: | 636ms |
