Hibernate
подскажите пожалуйста в чем может быть ошибка ? hibernate.cfg.xml <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE hibernate-configuration PUBLIC "-//Hibernate/Hibernate Configuration DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-configuration-3.0.dtd"> <hibernate-configuration> <session-factory> <property name="hibernate.connection.driver_class">com.mysql.jdbc.Driver</property> <property name="hibernate.dialect">org.hibernate.dialect.MySQLDialect</property> <property name="hibernate.connection.url">jdbc:mysql://localhost/mydb</property> <property name="hibernate.connection.password"></property> <property name="hibernate.connection.username"></property> <property name="hibernate.c3p0.max_size">20</property> <property name="hibernate.c3p0.max_statements">50</property> <property name="hibernate.c3p0.min_size">5</property> org.hibernate.HibernateException: Hibernate Dialect must be explicitly set at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:57) at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39) at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:378) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:110) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:1869) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1162) at test.com.CustomerBean.getAll(CustomerBean.java:24) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) <property name="hibernate.c3p0.timeout">1800</property> </session-factory> </hibernate-configuration> ... |
| 24.04.2006, 13:51:03 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2149499]: |
51ms |
52ms |
| others: | 335ms |
| total: | 516ms |
