Проблема с JBulder'ом
Доброе всем время суток. Установил я Jbuilder скачанный с борландовского сайта, а он не запускается, пишет типа ошибки: В чем дело? Заранее спасибо. An unexpected exception has been detected in native code outside the VM. Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at PC=0x4B86B0A Function=Java_sun_print_Win32PrintJob_endPrintRawData+0x946 Library=C:\Borland\JBuilder2005\jdk1.4\jre\bin\awt.dll Current Java thread: at sun.awt.windows.Win32SurfaceData.initDDraw(Native Method) at sun.awt.windows.Win32SurfaceData.<clinit>(Win32SurfaceData.java:269) at sun.awt.windows.D3DBlitLoops.register(D3DBlitLoops.java:39) at sun.awt.windows.Win32OffScreenSurfaceData.initD3D(Win32OffScreenSurfaceData.java:92) at sun.awt.windows.Win32OffScreenSurfaceData.<clinit>(Win32OffScreenSurfaceData.java:134) at sun.awt.windows.WToolkit.initIDs(Native Method) at sun.awt.windows.WToolkit.<clinit>(WToolkit.java:94) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:141) at java.awt.Toolkit$2.run(Toolkit.java:748) at java.security.AccessController.doPrivileged(Native Method) at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:739) - locked <0x3efcca40> (a java.lang.Class) at com.borland.primetime.util.Images.getImage(Unknown Source) - locked <0x3efae298> (a java.lang.Class) at com.borland.primetime.util.Images.getImage(Unknown Source) at com.borland.primetime.util.Images.getImage(Unknown Source) at com.borland.jbuilder.ide.JBuilderIcons.<clinit>(Unknown Source) at com.borland.jbuilder.node.JBProject.<clinit>(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:141) at com.borland.jbuilder.personality.JBuilderPersonalities.a(Unknown Source) at com.borland.jbuilder.personality.JBuilderPersonalities.initOpenTool(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:324) at com.borland.primetime.PrimeTime.f(Unknown Source) at com.borland.primetime.PrimeTime.initializeOpenTools(Unknown Source) at com.borland.primetime.PrimeTime.initializeOpenTools(Unknown Source) at com.borland.primetime.PrimeTime.start(Unknown Source) at com.borland.jbuilder.JBuilder.main(Unknown Source) Dynamic libraries: 0x00400000 - 0x0042D000 C:\Borland\JBuilder2005\bin\JBuilder.exe 0x77F50000 - 0x77FF8000 C:\WINDOWS\System32\ntdll.dll 0x77E60000 - 0x77F48000 C:\WINDOWS\system32\kernel32.dll 0x77DC0000 - 0x77E5E000 C:\WINDOWS\system32\ADVAPI32.DLL 0x78000000 - 0x78086000 C:\WINDOWS\system32\RPCRT4.dll 0x71AB0000 - 0x71AB9000 C:\WINDOWS\System32\WSOCK32.DLL 0x71A90000 - 0x71AA5000 C:\WINDOWS\System32\WS2_32.dll 0x77C00000 - 0x77C53000 C:\WINDOWS\system32\msvcrt.dll 0x71A80000 - 0x71A88000 C:\WINDOWS\System32\WS2HELP.dll 0x77C60000 - 0x77CA0000 C:\WINDOWS\system32\GDI32.DLL 0x77D30000 - 0x77DBC000 C:\WINDOWS\system32\USER32.dll 0x08000000 - 0x08138000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\client\jvm.dll 0x76B20000 - 0x76B4D000 C:\WINDOWS\System32\WINMM.dll 0x6BD00000 - 0x6BD0D000 C:\WINDOWS\System32\SYNCOR11.DLL 0x746E0000 - 0x74724000 C:\WINDOWS\System32\MSCTF.dll 0x00F00000 - 0x01097000 C:\Program Files\Ad Muncher\AdMunch.dll 0x60AF0000 - 0x60AF8000 C:\WINDOWS\System32\mslbui.dll 0x10000000 - 0x10007000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\hpi.dll 0x003F0000 - 0x003FE000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\verify.dll 0x01140000 - 0x01159000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\java.dll 0x01160000 - 0x0116D000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\zip.dll 0x04B20000 - 0x04C2F000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\awt.dll 0x72FC0000 - 0x72FE3000 C:\WINDOWS\System32\WINSPOOL.DRV 0x76360000 - 0x7637C000 C:\WINDOWS\System32\IMM32.dll 0x771A0000 - 0x772C1000 C:\WINDOWS\system32\ole32.dll 0x04C30000 - 0x04C80000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\fontmanager.dll 0x51000000 - 0x51050000 C:\WINDOWS\System32\ddraw.dll 0x73B80000 - 0x73B86000 C:\WINDOWS\System32\DCIMAN32.dll 0x5C000000 - 0x5C0C8000 C:\WINDOWS\System32\D3DIM700.DLL 0x76C80000 - 0x76CA2000 C:\WINDOWS\system32\imagehlp.dll 0x6DAA0000 - 0x6DB1D000 C:\WINDOWS\system32\DBGHELP.dll 0x77BF0000 - 0x77BF7000 C:\WINDOWS\system32\VERSION.dll 0x76BE0000 - 0x76BEB000 C:\WINDOWS\System32\PSAPI.DLL Heap at VM Abort: Heap def new generation total 2304K, used 893K [0x10010000, 0x10280000, 0x139c0000) eden space 2112K, 33% used [0x10010000, 0x100bf5d0, 0x10220000) from space 192K, 99% used [0x10220000, 0x1024fff8, 0x10250000) to space 192K, 0% used [0x10250000, 0x10250000, 0x10280000) tenured generation total 30272K, used 5101K [0x139c0000, 0x15750000, 0x3ee10000) the space 30272K, 16% used [0x139c0000, 0x13ebb478, 0x13ebb600, 0x15750000) compacting perm gen total 4096K, used 2569K [0x3ee10000, 0x3f210000, 0x42e10000) the space 4096K, 62% used [0x3ee10000, 0x3f0926e8, 0x3f092800, 0x3f210000) Local Time = Tue Jun 06 08:23:12 2006 Elapsed Time = 1 # # The exception above was detected in native code outside the VM # # Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode) # ... |
| 06.06.2006, 08:28:29 |
junior jabberДоброе всем время суток. Установил я Jbuilder скачанный с борландовского сайта, а он не запускается, пишет типа ошибки: В чем дело? Заранее спасибо. An unexpected exception has been detected in native code outside the VM. Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at PC=0x4B86B0A Function=Java_sun_print_Win32PrintJob_endPrintRawData+0x946 Library=C:\Borland\JBuilder2005\jdk1.4\jre\bin\awt.dll Current Java thread: at sun.awt.windows.Win32SurfaceData.initDDraw(Native Method) at sun.awt.windows.Win32SurfaceData.<clinit>(Win32SurfaceData.java:269) at sun.awt.windows.D3DBlitLoops.register(D3DBlitLoops.java:39) at sun.awt.windows.Win32OffScreenSurfaceData.initD3D(Win32OffScreenSurfaceData.java:92) at sun.awt.windows.Win32OffScreenSurfaceData.<clinit>(Win32OffScreenSurfaceData.java:134) at sun.awt.windows.WToolkit.initIDs(Native Method) at sun.awt.windows.WToolkit.<clinit>(WToolkit.java:94) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:141) at java.awt.Toolkit$2.run(Toolkit.java:748) at java.security.AccessController.doPrivileged(Native Method) at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:739) - locked <0x3efcca40> (a java.lang.Class) at com.borland.primetime.util.Images.getImage(Unknown Source) - locked <0x3efae298> (a java.lang.Class) at com.borland.primetime.util.Images.getImage(Unknown Source) at com.borland.primetime.util.Images.getImage(Unknown Source) at com.borland.jbuilder.ide.JBuilderIcons.<clinit>(Unknown Source) at com.borland.jbuilder.node.JBProject.<clinit>(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:141) at com.borland.jbuilder.personality.JBuilderPersonalities.a(Unknown Source) at com.borland.jbuilder.personality.JBuilderPersonalities.initOpenTool(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:324) at com.borland.primetime.PrimeTime.f(Unknown Source) at com.borland.primetime.PrimeTime.initializeOpenTools(Unknown Source) at com.borland.primetime.PrimeTime.initializeOpenTools(Unknown Source) at com.borland.primetime.PrimeTime.start(Unknown Source) at com.borland.jbuilder.JBuilder.main(Unknown Source) Dynamic libraries: 0x00400000 - 0x0042D000 C:\Borland\JBuilder2005\bin\JBuilder.exe 0x77F50000 - 0x77FF8000 C:\WINDOWS\System32\ntdll.dll 0x77E60000 - 0x77F48000 C:\WINDOWS\system32\kernel32.dll 0x77DC0000 - 0x77E5E000 C:\WINDOWS\system32\ADVAPI32.DLL 0x78000000 - 0x78086000 C:\WINDOWS\system32\RPCRT4.dll 0x71AB0000 - 0x71AB9000 C:\WINDOWS\System32\WSOCK32.DLL 0x71A90000 - 0x71AA5000 C:\WINDOWS\System32\WS2_32.dll 0x77C00000 - 0x77C53000 C:\WINDOWS\system32\msvcrt.dll 0x71A80000 - 0x71A88000 C:\WINDOWS\System32\WS2HELP.dll 0x77C60000 - 0x77CA0000 C:\WINDOWS\system32\GDI32.DLL 0x77D30000 - 0x77DBC000 C:\WINDOWS\system32\USER32.dll 0x08000000 - 0x08138000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\client\jvm.dll 0x76B20000 - 0x76B4D000 C:\WINDOWS\System32\WINMM.dll 0x6BD00000 - 0x6BD0D000 C:\WINDOWS\System32\SYNCOR11.DLL 0x746E0000 - 0x74724000 C:\WINDOWS\System32\MSCTF.dll 0x00F00000 - 0x01097000 C:\Program Files\Ad Muncher\AdMunch.dll 0x60AF0000 - 0x60AF8000 C:\WINDOWS\System32\mslbui.dll 0x10000000 - 0x10007000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\hpi.dll 0x003F0000 - 0x003FE000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\verify.dll 0x01140000 - 0x01159000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\java.dll 0x01160000 - 0x0116D000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\zip.dll 0x04B20000 - 0x04C2F000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\awt.dll 0x72FC0000 - 0x72FE3000 C:\WINDOWS\System32\WINSPOOL.DRV 0x76360000 - 0x7637C000 C:\WINDOWS\System32\IMM32.dll 0x771A0000 - 0x772C1000 C:\WINDOWS\system32\ole32.dll 0x04C30000 - 0x04C80000 C:\Borland\JBuilder2005\jdk1.4\jre\bin\fontmanager.dll 0x51000000 - 0x51050000 C:\WINDOWS\System32\ddraw.dll 0x73B80000 - 0x73B86000 C:\WINDOWS\System32\DCIMAN32.dll 0x5C000000 - 0x5C0C8000 C:\WINDOWS\System32\D3DIM700.DLL 0x76C80000 - 0x76CA2000 C:\WINDOWS\system32\imagehlp.dll 0x6DAA0000 - 0x6DB1D000 C:\WINDOWS\system32\DBGHELP.dll 0x77BF0000 - 0x77BF7000 C:\WINDOWS\system32\VERSION.dll 0x76BE0000 - 0x76BEB000 C:\WINDOWS\System32\PSAPI.DLL Heap at VM Abort: Heap def new generation total 2304K, used 893K [0x10010000, 0x10280000, 0x139c0000) eden space 2112K, 33% used [0x10010000, 0x100bf5d0, 0x10220000) from space 192K, 99% used [0x10220000, 0x1024fff8, 0x10250000) to space 192K, 0% used [0x10250000, 0x10250000, 0x10280000) tenured generation total 30272K, used 5101K [0x139c0000, 0x15750000, 0x3ee10000) the space 30272K, 16% used [0x139c0000, 0x13ebb478, 0x13ebb600, 0x15750000) compacting perm gen total 4096K, used 2569K [0x3ee10000, 0x3f210000, 0x42e10000) the space 4096K, 62% used [0x3ee10000, 0x3f0926e8, 0x3f092800, 0x3f210000) Local Time = Tue Jun 06 08:23:12 2006 Elapsed Time = 1 # # The exception above was detected in native code outside the VM # # Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode) # таже фигня была, кроме как анинсталл больше нифига не подошло ... |
| 06.06.2006, 10:03:29 |
делал, анинстал и снова инсталил, несколько раз и каждый раз вот такая ерунда :( ... |
| 06.06.2006, 10:24:57 |
junior jabberделал, анинстал и снова инсталил, несколько раз и каждый раз вот такая ерунда :( значит плохо реестр чистил ... |
| 06.06.2006, 15:51:02 |
Последний раз, после похожих вылетов VM, на машине был обнаружен вирус. Шаманство конечно, но вдруг? ====================== - Я подхожу к клетке с медведем панда... Видите, какие у него черные круги под глазами?! Медведь панда как бы всем своим видом говорит нам: "Не бухайте!" ====================== ... |
| 06.06.2006, 22:59:11 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2149023]: |
28ms |
53ms |
| others: | 287ms |
| total: | 410ms |
