Что за ошибка ????
"C:\Program Files\Java\jdk1.5.0\bin\java" -Didea.launcher.port=7541 "-Didea.launcher.bin.path=C:\Program Files\IntelliJ IDEA 5.1\bin" -Dfile.encoding=windows-1251 -classpath "C:\Program Files\Java\jdk1.5.0\jre\lib\charsets.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\deploy.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\javaws.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\jce.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\plugin.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\rt.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\ext\dnsns.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\ext\localedata.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\ext\sunjce_provider.jar;C:\Program Files\Java\jdk1.5.0\jre\lib\ext\sunpkcs11.jar;C:\IdeaProjects\untitled\classes;C:\Program Files\Apache Software Foundation\jdbc\lib\classes12.jar;C:\Program Files\IntelliJ IDEA 5.1\lib\idea_rt.jar" com.intellij.rt.execution.application.AppMain JdbcTest java.sql.SQLException: Исключение ввода/вывода: Connection refused(DESCRIPTION=(TMP=)(VSNNUM=153092352)(ERR=12505)(ERROR_STACK=(ERROR=(CODE=12505)(EMFI=4)))) at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:134) at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:179) at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:333) at oracle.jdbc.driver.OracleConnection.<init>(OracleConnection.java:404) at oracle.jdbc.driver.OracleDriver.getConnectionInstance(OracleDriver.java:468) at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:314) at java.sql.DriverManager.getConnection(DriverManager.java:525) at java.sql.DriverManager.getConnection(DriverManager.java:171) at JdbcTest.main(JdbcTest.java:20) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at com.intellij.rt.execution.application.AppMain.main(AppMain.java:90) Process finished with exit code 0 ... |
| 19.06.2006, 15:17:50 |
Что за ошибка ????
Исключение ввода/вывода: Connection refused - попытка подлкючения к БД Oracle, служба Oracle развернута, но нет инстанса, для которого производится попытка соединения, соответсвено служба Oracle отбрасывает. ... |
| 19.06.2006, 16:00:38 |
Что за ошибка ????
mors78Исключение ввода/вывода: Connection refused - попытка подлкючения к БД Oracle, служба Oracle развернута, но нет инстанса, для которого производится попытка соединения, соответсвено служба Oracle отбрасывает. это может возникнуть из за того что JDK jdk1.5.0 a драйвер Oracle JDBC Drivers release 9.2.0 в реад ме пишут New classes file name for JDK 1.4 ... |
| 19.06.2006, 16:05:35 |
Что за ошибка ????
Message ORA-12505:TNS:listener could not resolve SID given in connect descriptor Cause The SID in CONNECT_DATA was not found in the listener`s tables. Action Check to make sure that the SID specified is correct. The SIDs that are currently registered with the listener can be obtained by typing "LSNRCTL SERVICES listener_name". These SIDs correspond to SID_NAMEs in TNSNAMES.ORA, or DB_NAMES in the INIT.ORA file. ... |
| 19.06.2006, 16:26:14 |
Что за ошибка ????
а как правильно написать строку подключения у меня вот так: DriverManager.registerDriver (new oracle.jdbc.driver.OracleDriver()); Connection conn = DriverManager.getConnection ("jdbc:oracle:thin:@server_name:1521:base","login","pass"); ... |
| 19.06.2006, 16:35:57 |
Что за ошибка ????
Madfish mors78Исключение ввода/вывода: Connection refused - попытка подлкючения к БД Oracle, служба Oracle развернута, но нет инстанса, для которого производится попытка соединения, соответсвено служба Oracle отбрасывает. это может возникнуть из за того что JDK jdk1.5.0 a драйвер Oracle JDBC Drivers release 9.2.0 в реад ме пишут New classes file name for JDK 1.4 может быть, у меня c Oracle 9 все работает и 1.3,1.4, 5 и с 6 Java. Я думаю надо: 1) попробовать подключиться другими средствами к БД (типа PL/SQL Developer и.т.д.) - проверить что БД в принципе работает. 2) поискать проверить строку подключения к БД (наверное где-то в конфиг файлах) а потом уже с версии проверять (... или это уже все сделано :-) ?) ... |
| 19.06.2006, 16:43:02 |
Что за ошибка ????
Madfishа как правильно написать строку подключения у меня вот так: DriverManager.registerDriver (new oracle.jdbc.driver.OracleDriver()); Connection conn = DriverManager.getConnection ("jdbc:oracle:thin:@server_name:1521:base","login","pass"); да все верно, можно вместо server_name - IP, ошибка возникает если не правильно указать base. Вот так все работает: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ... |
| 19.06.2006, 16:49:32 |
Что за ошибка ????
mors78 Madfish mors78Исключение ввода/вывода: Connection refused - попытка подлкючения к БД Oracle, служба Oracle развернута, но нет инстанса, для которого производится попытка соединения, соответсвено служба Oracle отбрасывает. это может возникнуть из за того что JDK jdk1.5.0 a драйвер Oracle JDBC Drivers release 9.2.0 в реад ме пишут New classes file name for JDK 1.4 может быть, у меня c Oracle 9 все работает и 1.3,1.4, 5 и с 6 Java. Я думаю надо: 1) попробовать подключиться другими средствами к БД (типа PL/SQL Developer и.т.д.) - проверить что БД в принципе работает. 2) поискать проверить строку подключения к БД (наверное где-то в конфиг файлах) а потом уже с версии проверять (... или это уже все сделано :-) ?) база работает точно строка вроде как надо написана Connection conn = DriverManager.getConnection ("jdbc:oracle:thin:@192.168.0.125:1521:W2KL","dlo_adm","corban"); ... |
| 19.06.2006, 16:49:57 |
Что за ошибка ????
this.connection.setAutoCommit(false); - лишнее :) ... |
| 19.06.2006, 16:51:37 |
Что за ошибка ????
Да что то гдето видел про версии, но сейчас не найду, (и так на всякий случай, Firewall ?.. -проверить настройки). Еще можно через родной Oracle драйвер и при наличии клиента Oracle (TNSName) Код: plaintext 1. 2. 3. 4. 5. ... |
| 19.06.2006, 17:02:34 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2148930]: |
25ms |
43ms |
75ms |
| others: | 314ms |
| total: | 515ms |
