Запустить пример JAXB...
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. Пишет: javax.xml.bind.JAXBException: test.MyObject nor any of its super class is known to this context at com.sun.xml.bind.v2.runtime.JAXBContextImpl.getBeanInfo(JAXBContextImpl.java:474) at com.sun.xml.bind.v2.runtime.XMLSerializer.childAsRoot(XMLSerializer.java:448) at com.sun.xml.bind.v2.runtime.MarshallerImpl.write(MarshallerImpl.java:292) at com.sun.xml.bind.v2.runtime.MarshallerImpl.marshal(MarshallerImpl.java:221) at javax.xml.bind.helpers.AbstractMarshallerImpl.marshal(AbstractMarshallerImpl.java:91) at ru.rtk.ipds.reports.reportscallsvolume.test.TestJAXB.<init>(TestJAXB.java:44) at ru.rtk.ipds.reports.reportscallsvolume.test.TestJAXB.main(TestJAXB.java:31) Чего то уже башка не варит, не пойму, может какие анотации в MyObject написать ... ... |
| 19.06.2006, 17:24:00 |
Пример от SUN Using JAXB 2.0 to persist your own classes to XML Не работает :( : javax.xml.bind.MarshalException - with linked exception: [com.sun.istack.SAXException2: unable to marshal type "test.MyObject" as an element because it is missing an @XmlRootElement annotation] at com.sun.xml.bind.v2.runtime.MarshallerImpl.write(MarshallerImpl.java:295) at com.sun.xml.bind.v2.runtime.MarshallerImpl.marshal(MarshallerImpl.java:221) at javax.xml.bind.helpers.AbstractMarshallerImpl.marshal(AbstractMarshallerImpl.java:70) at ru.rtk.ipds.reports.reportscallsvolume.test.TestJAXB.<init>(TestJAXB.java:30) at ru.rtk.ipds.reports.reportscallsvolume.test.TestJAXB.main(TestJAXB.java:22) src Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. ... |
| 22.06.2006, 09:37:36 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2148898]: |
27ms |
75ms |
94ms |
| others: | 310ms |
| total: | 580ms |
