При запуске скрипта выдает "java.sql.SQLException: Unknown database 'Auth'
База Auth существует. Что не так?
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
import java.sql.*;
public class JDBCTest1
public static void main(String[] args)
String driver = "com.mysql.jdbc.jdbc2.optional.MysqlConnectionPoolDataSource";
String url = "jdbc:mysql://127.0.0.1:3306/Auth";
String fName;
int fId;
Object fSalary;
Connection con= null ;
Statement st;
ResultSet rs;
try
Class .forName(driver);
catch (ClassNotFoundException cnfe)
System.err.println("Can't find JDBC driver");
cnfe.printStackTrace();
System.exit( 1 );
try
con=DriverManager.getConnection(url, "user", "");
catch (SQLException se)
System.err.println("DB connection error");
se.printStackTrace();
System.exit( 1 );
try
st = con.createStatement();
rs = st.executeQuery("select id, adress, login from worker");
while (rs.next())
fId = rs.getInt("id");
fName = rs.getString( 2 );
fSalary = rs.getObject( 3 );
System.out.println("id=" + fId + ", name=" + fName+",salary="+fSalary.toString());
System.err.println("JDBC execution error");
System.exit( 1 );
try
con.close();
System.err.println("Connection close error");
System.exit( 1 );
Драйвер mysql-connector-java-3.1.13-bin.jar
Полный текст ошибки
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
DB connection error
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java: 2975 )
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java: 798 )
at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java: 1256 )
at com.mysql.jdbc.Connection.createNewIO(Connection.java: 2568 )
at com.mysql.jdbc.Connection.<init>(Connection.java: 1485 )
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java: 266 )
at java.sql.DriverManager.getConnection(DriverManager.java: 525 )
at java.sql.DriverManager.getConnection(DriverManager.java: 171 )
at JDBCTest1.main(JDBCTest1.java: 26 )
Java Result: 1
BUILD SUCCESSFUL (total time: 4 seconds)
