Jasper Reports и iReport
Попробовал на iReport запустить пример отчета JFreeChartReport и вылетела у меня ошибочка: Error compiling the report java source! it.businesslogic.ireport.ReportClassLoader@1d84118 10 [Thread-10] ERROR digester.Digester - Digester.getParser: org.xml.sax.SAXNotRecognizedException: http://apache.org/xml/features/validation/dynamic at gnu.xml.aelfred2.JAXPFactory.setFeature(JAXPFactory.java:102) at org.apache.commons.digester.parser.XercesParser.configureXerces(XercesParser.java:185) at org.apache.commons.digester.parser.XercesParser.newSAXParser(XercesParser.java:138) at org.apache.commons.digester.ParserFeatureSetterFactory.newSAXParser(ParserFeatureSetterFactory.java:71) at org.apache.commons.digester.Digester.getParser(Digester.java:692) at org.apache.commons.digester.Digester.getXMLReader(Digester.java:899) at org.apache.commons.digester.Digester.parse(Digester.java:1647) at net.sf.jasperreports.engine.xml.JRXmlLoader.loadXML(JRXmlLoader.java:238) at net.sf.jasperreports.engine.xml.JRXmlLoader.loadXML(JRXmlLoader.java:225) at net.sf.jasperreports.engine.xml.JRXmlLoader.load(JRXmlLoader.java:213) at net.sf.jasperreports.engine.xml.JRXmlLoader.load(JRXmlLoader.java:167) at net.sf.jasperreports.engine.xml.JRXmlLoader.load(JRXmlLoader.java:151) at net.sf.jasperreports.engine.JasperCompileManager.compileReportToFile(JasperCompileManager.java:107) at it.businesslogic.ireport.IReportCompiler.run(IReportCompiler.java:477) at java.lang.Thread.run(Unknown Source) java.lang.NullPointerException at org.apache.commons.digester.Digester.getXMLReader(Digester.java:899) at org.apache.commons.digester.Digester.parse(Digester.java:1647) at net.sf.jasperreports.engine.xml.JRXmlLoader.loadXML(JRXmlLoader.java:238) at net.sf.jasperreports.engine.xml.JRXmlLoader.loadXML(JRXmlLoader.java:225) at net.sf.jasperreports.engine.xml.JRXmlLoader.load(JRXmlLoader.java:213) at net.sf.jasperreports.engine.xml.JRXmlLoader.load(JRXmlLoader.java:167) at net.sf.jasperreports.engine.xml.JRXmlLoader.load(JRXmlLoader.java:151) at net.sf.jasperreports.engine.JasperCompileManager.compileReportToFile(JasperCompileManager.java:107) at it.businesslogic.ireport.IReportCompiler.run(IReportCompiler.java:477) at java.lang.Thread.run(Unknown Source) Что это значит и как его всетаки запустить? ... |
| 05.07.2006, 11:06:12 |
И еще одна проблемка - не могу найти класс JFreeChartScriptlet. Подскажите плиз где его можно скачать. ... |
| 05.07.2006, 12:56:59 |
Dima11 wrote: > И еще одна проблемка - не могу найти класс JFreeChartScriptlet. > Подскажите плиз где его можно скачать. Поищи тут: http://sourceforge.net/projects/jfreechart Posted via ActualForum NNTP Server 1.3 ... |
| 05.07.2006, 13:11:27 |
Не нашел... ... |
| 05.07.2006, 14:24:46 |
http://www.kickjava.com/src/JFreeChartScriptlet.java.htm * JasperReports - Free Java report-generating library. 7 * Copyright (C) 2001-2005 JasperSoft Corporation http://www.jaspersoft.com Значит искать надо где-то на http://www.jaspersoft.com ... |
| 05.07.2006, 14:37:42 |
Спасибо. Стянул исходник с http://www.kickjava.com/src/JFreeChartScriptlet.java.htm, включил в проект, запустил и вот: Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError at org.jfree.chart.ChartFactory.createPieChart3D(ChartFactory.java:492) at JFreeChartScriptlet.afterReportInit(JFreeChartScriptlet.java:67) at net.sf.jasperreports.engine.JRAbstractScriptlet.callAfterReportInit(JRAbstractScriptlet.java:179) at net.sf.jasperreports.engine.fill.JRVerticalFiller.fillReportStart(JRVerticalFiller.java:211) и т.д. Какие есть идеи по этому поводу? ... |
| 05.07.2006, 15:54:56 |
Скорее всего надо тянуть не исходник, а искать всю библиотеку с этим классом на jaspersoft.com. Posted via ActualForum NNTP Server 1.3 ... |
| 05.07.2006, 15:57:50 |
Мне кажется что я просто не правильно пытаюсь строить график... В файле JFreeChartScriptlet.java находятся данные для примера который пытаюсь запустить. Т.е. по идее, если данные брать из базы, класс JFreeChartScriptlet вообще не будет нужен... Попробую разобраться... ... |
| 05.07.2006, 16:26:54 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2148768]: |
321ms |
55ms |
| others: | 333ms |
| total: | 777ms |
