::: JSF::: из - за чего выдается такая ошибка?
org.apache.jasper.JasperException: javax.servlet.jsp.JspException: Can't find bundle for base name bundleres, locale ru_RU org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:510) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:375) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:322) com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:147) com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:87) com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200) com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:117) javax.faces.webapp.FacesServlet.service(FacesServlet.java:198) root cause javax.servlet.ServletException: javax.servlet.jsp.JspException: Can't find bundle for base name bundleres, locale ru_RU org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:854) org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791) org.apache.jsp.create_jsp._jspService(org.apache.jsp.create_jsp:87) org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:332) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:322) com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:147) com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:87) com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200) com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:117) javax.faces.webapp.FacesServlet.service(FacesServlet.java:198) root cause java.util.MissingResourceException: Can't find bundle for base name bundleres, locale ru_RU java.util.ResourceBundle.throwMissingResourceException(ResourceBundle.java:836) java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:805) java.util.ResourceBundle.getBundle(ResourceBundle.java:699) com.sun.faces.util.MessageFactory.getMessage(MessageFactory.java:122) com.sun.faces.util.MessageFactory.getMessage(MessageFactory.java:108) com.sun.faces.util.Util.getExceptionMessageString(Util.java:426) com.sun.faces.renderkit.html_basic.HtmlBasicRenderer.getForComponent(HtmlBasicRenderer.java:376) com.sun.faces.renderkit.html_basic.HtmlBasicRenderer.getMessageIter(HtmlBasicRenderer.java:315) com.sun.faces.renderkit.html_basic.MessageRenderer.encodeEnd(MessageRenderer.java:127) javax.faces.component.UIComponentBase.encodeEnd(UIComponentBase.java:712) javax.faces.webapp.UIComponentTag.encodeEnd(UIComponentTag.java:616) javax.faces.webapp.UIComponentTag.doEndTag(UIComponentTag.java:539) com.sun.faces.taglib.html_basic.MessageTag.doEndTag(MessageTag.java:288) org.apache.jsp.create_jsp._jspx_meth_h_message_0(org.apache.jsp.create_jsp:283) org.apache.jsp.create_jsp._jspx_meth_h_form_0(org.apache.jsp.create_jsp:172) org.apache.jsp.create_jsp._jspx_meth_f_view_0(org.apache.jsp.create_jsp:123) org.apache.jsp.create_jsp._jspService(org.apache.jsp.create_jsp:80) org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:332) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:322) com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:147) com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:87) com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200) com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:117) javax.faces.webapp.FacesServlet.service(FacesServlet.java:198) ... |
| 24.11.2006, 12:09:43 |
не может найти файл bundleres_RU.properties ... |
| 24.11.2006, 12:31:01 |
сделал я ему это файлик bundleres_RU.properties: companyname = Êîìïàíèÿ; bossname = Ðóêîâîäèòåëü; phone = Òåëåôîí; Save = Ñîõðàíèòü; Иероглифы эклипс написал, потом посмотрел я одну умную книжку а там файлики *_ru.properties выглядят так: # Login LoginCaption=Введите имя пользователя PasswordCaption=Пароль SubmitButtonTitle=отправит SubmitButtonImage=/images/submit_ru.gif SubmitButtonOverImage=/images/submit_over_ru.gif т.е. переводятцо в юникод, правильно я понимаю? Как этого в эклипсе добитьцо? ... |
| 24.11.2006, 12:43:21 |
в jdk есть утилита native2asci ... |
| 24.11.2006, 12:55:42 |
Deadyв jdk есть утилита native2asci вот тока как ей пользоваться гугль мне не подсказал ) ... |
| 24.11.2006, 14:29:16 |
первая ссылка , заходим, видим: автор native2ascii - Native-to-ASCII Converter Converts a file with native-encoded characters (characters which are non-Latin 1 and non-Unicode) to one with Unicode-encoded characters. SYNOPSIS native2ascii [options] [inputfile [outputfile]] DESCRIPTION The Java compiler and other Java tools can only process files which contain Latin-1 and/or Unicode-encoded (["\udddd"] notation) characters. native2ascii converts files which contain other character encodings into files containing Latin-1 and/or Unicode-encoded charaters. If outputfile is omitted, standard output is used for output. If, in addition, inputfile is omitted, standard input is used for input. OPTIONS -reverse Perform the reverse operation: convert a file with Latin-1 and/or Unicode encoded characters to one with native-encoded characters. -encoding encoding_name Specify the encoding name which is used by the conversion procedure. The default encoding is taken from System property file.encoding. The encoding_name string must be taken from the first column of the table of supported encodings in the Supported Encodings document. -Joption Pass option to the Java virtual machine, where option is one of the options described on the reference page for the java application launcher. For example, -J-Xms48m sets the startup memory to 48 megabytes. ... |
| 24.11.2006, 14:59:51 |
спасибо, видно я че то туплю, преред пятничной пъянкой ) страно что Эклипс этого не умеет делать. ... |
| 24.11.2006, 15:21:49 |
я в командной строке сделал: native2ascii -encoding UTF8 inputbundleres_RU.properties bundleres_RU.properties был у меня inputbundleres_RU.properties: #create companyname = компания; bossname = руководство; phone = телефон; Save = сохранить; а конвертнулось это все от во что (bundleres_RU.properties): #create companyname = вап; bossname = руководство; phone = телефон; Save = сохранить; деплою этот файлик куда нада, а мне томкат опять кричит:Can't find bundle for base name bundleres, locale ru и в faces-config.xml прописано: <application> <locale-config> <default-locale>en</default-locale> <supported-locale>en</supported-locale> <supported-locale>ru</supported-locale> </locale-config> <message-bundle>bundleres</message-bundle> </application> че делать ни знаю? ... |
| 24.11.2006, 15:50:42 |
А можно вообще писать JSF - приложения без файлов *.properties ??? ... |
| 27.11.2006, 09:15:10 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2147389]: |
30ms |
61ms |
62ms |
| others: | 309ms |
| total: | 525ms |
