Eclipse + assert
Умная книжка: авторSuppose you tell the compiler that your code is version 1.4 or later, for instance: javac -source 1.4 NotQuiteSoOldCode.java In this case, the compiler will issue errors when it discovers the word assert used as an identifier. делаю: Window -> Preferences -> Java -> Compiler -> CCL = 1.4 Код: plaintext 1. 2. 3. 4. 5. 6. 7. Компилится и запускается "на ура". Глюк IDE? JDK 5.0, Eclipse 3.2.1 ... |
| 08.12.2006, 02:17:38 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2147228]: |
53ms |
84ms |
| others: | 294ms |
| total: | 519ms |
