Наверно многие начанали с этого. Делаю всю по туториалу САНа.
После билда и деплоймента захожу на JSP страничку. Нажимаю Submiе и получаю:
1.
2.
3.
4.
5.
6.
7.
8.
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: viewId:/greeting.jsp - View /greeting.jsp could not be restored.
root cause
javax.faces.application.ViewExpiredException: viewId:/greeting.jsp - View /greeting.jsp could not be restored.
note The full stack traces of the exception and its root causes are available in the Sun Java System Application Server Platform Edition 9 .0_01 logs.
В логах appserver'a:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
executePhase(RESTORE_VIEW 1 ,com.sun.faces.context.FacesContextImpl@1dad2ac) threw exception
at com.sun.faces.lifecycle.RestoreViewPhase.execute(RestoreViewPhase.java: 205 )
at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java: 244 )
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java: 113 )
at javax.faces.webapp.FacesServlet.service(FacesServlet.java: 244 )
at org.apache.catalina.core.ApplicationFilterChain.servletService(ApplicationFilterChain.java: 397 )
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java: 278 )
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java: 566 )
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java: 536 )
at org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java: 240 )
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java: 179 )
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java: 73 )
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java: 182 )
at com.sun.enterprise.web.VirtualServerPipeline.invoke(VirtualServerPipeline.java: 120 )
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java: 939 )
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java: 137 )
at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java: 239 )
at com.sun.enterprise.web.connector.grizzly.ProcessorTask.invokeAdapter(ProcessorTask.java: 667 )
at com.sun.enterprise.web.connector.grizzly.ProcessorTask.processNonBlocked(ProcessorTask.java: 574 )
at com.sun.enterprise.web.connector.grizzly.ProcessorTask.process(ProcessorTask.java: 844 )
at com.sun.enterprise.web.connector.grizzly.ReadTask.executeProcessorTask(ReadTask.java: 287 )
at com.sun.enterprise.web.connector.grizzly.ReadTask.doTask(ReadTask.java: 212 )
at com.sun.enterprise.web.connector.grizzly.TaskBase.run(TaskBase.java: 252 )
at com.sun.enterprise.web.connector.grizzly.WorkerThread.run(WorkerThread.java: 75 )
StandardWrapperValve[Faces Servlet]: Servlet.service() for servlet Faces Servlet threw exception
Подскажите, плз, куда смотреть? Просто ошибка "View /greeting.jsp could not be restored." совершенно не наводит ни на какие мысли. Это ошибка EJB или JSP или надо рыть в конф файлах...
Дайте направление, плз...
