Oracle ADF SRDemo Application
Хай. Пытаюсь заставить работать демку "Oracle ADF SRDemo Application" из под JDeveloper 10.1.3. Получаю HTTP 500. В логе девелопера сл. ошибки. Кто знает, что оно значит, отзовись, плиз... авторU:\Program Files\jdevstudio10131\jdk\bin\javaw.exe -jar U:\Program Files\jdevstudio10131\j2ee\home\admin.jar ormi://192.168.1.79:23891 oc4jadmin **** -updateConfig Jan 2, 2007 2:48:39 PM com.oracle.corba.ee.impl.orb.ORBServerExtensionProviderImpl preInitApplicationServer WARNING: ORB ignoring configuration changes. Restart OC4J to apply new ORB configuration. Jan 2, 2007 2:48:40 PM com.evermind.server.jms.JMSMessages log SEVERE: ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. 07/01/02 14:48:40 *** (SEVERE) ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. Jan 2, 2007 2:48:40 PM com.evermind.server.jms.JMSMessages log SEVERE: Failed to set the internal configuration of the OC4J JMS Server with: XMLJMSServerConfig[file:/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/config/jms.xml] java.lang.InstantiationException: ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. at com.evermind.server.jms.JMSUtils.make(JMSUtils.java:1072) at com.evermind.server.jms.JMSUtils.toInstantiationException(JMSUtils.java:1237) at com.evermind.server.jms.JMSServer.recoverState(JMSServer.java:1831) at com.evermind.server.jms.JMSServer.internalSetConfig(JMSServer.java:209) at com.evermind.server.jms.JMSServer.setConfig(JMSServer.java:182) at com.evermind.server.ApplicationServer.initializeJMS(ApplicationServer.java:2412) at com.evermind.server.ApplicationServer.setConfig(ApplicationServer.java:955) at com.evermind.server.OC4JRestarter.run(OC4JRestarter.java:35) at java.lang.Thread.run(Thread.java:595) Caused by: java.io.IOException: ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27) at java.lang.reflect.Constructor.newInstance(Constructor.java:494) at com.evermind.server.jms.JMSUtils.make(JMSUtils.java:1032) at com.evermind.server.jms.JMSMessages.log(JMSMessages.java:229) at com.evermind.server.jms.JMSServerMessages.severeLockPersistenceFile(JMSServerMessages.java:86) at com.evermind.server.jms.ServerFile.safeOpenFile(ServerFile.java:788) at com.evermind.server.jms.ServerFile.access$000(ServerFile.java:77) at com.evermind.server.jms.ServerFile$2.run(ServerFile.java:719) at oracle.oc4j.security.OC4JSecurity.doUnprivileged(OC4JSecurity.java:325) at com.evermind.server.jms.ServerFile.openFile(ServerFile.java:716) at com.evermind.server.jms.ServerFile.<init>(ServerFile.java:133) at com.evermind.server.jms.PersistentMap.loadFile(PersistentMap.java:100) at com.evermind.server.jms.PersistentMap.<init>(PersistentMap.java:61) at com.evermind.server.jms.JMSServer.recoverState(JMSServer.java:1823) ... 6 more 07/01/02 14:48:40 *** (SEVERE) Failed to set the internal configuration of the OC4J JMS Server with: XMLJMSServerConfig[file:/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/config/jms.xml] Jan 2, 2007 2:48:40 PM com.evermind.server.ServerMessages severeJmsServerStartupException SEVERE: Exception starting JMS server: Failed to set the internal configuration of the OC4J JMS Server with: XMLJMSServerConfig[file:/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/config/jms.xml] Jan 2, 2007 2:48:43 PM com.evermind.server.http.HttpMessages internalErrorWhileTryingToInstantiate SEVERE: Internal error raised tyring to instantiate web-application: webapp defined in web site OC4J 10g (10.1.3) Default Web Site. Application: datatags does not exist. Error creating Web application: webapp Ready message received from Oc4jNotifier. Embedded OC4J startup time: 10968 ms. Target URL -- http://192.168.1.79:8988/SRDemoADFBC/index.jspx U:\Program Files\jdevstudio10131\jdk\bin\javaw.exe -jar U:\Program Files\jdevstudio10131\j2ee\home\admin.jar ormi://192.168.1.79:23891 oc4jadmin **** -updateConfig Jan 2, 2007 3:00:36 PM com.oracle.corba.ee.impl.orb.ORBServerExtensionProviderImpl preInitApplicationServer WARNING: ORB ignoring configuration changes. Restart OC4J to apply new ORB configuration. Jan 2, 2007 3:00:37 PM com.evermind.server.jms.JMSMessages log SEVERE: ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. 07/01/02 15:00:37 *** (SEVERE) ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. Jan 2, 2007 3:00:37 PM com.evermind.server.jms.JMSMessages log SEVERE: Failed to set the internal configuration of the OC4J JMS Server with: XMLJMSServerConfig[file:/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/config/jms.xml] java.lang.InstantiationException: ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. at com.evermind.server.jms.JMSUtils.make(JMSUtils.java:1072) at com.evermind.server.jms.JMSUtils.toInstantiationException(JMSUtils.java:1237) at com.evermind.server.jms.JMSServer.recoverState(JMSServer.java:1831) at com.evermind.server.jms.JMSServer.internalSetConfig(JMSServer.java:209) at com.evermind.server.jms.JMSServer.setConfig(JMSServer.java:182) at com.evermind.server.ApplicationServer.initializeJMS(ApplicationServer.java:2412) at com.evermind.server.ApplicationServer.setConfig(ApplicationServer.java:955) at com.evermind.server.OC4JRestarter.run(OC4JRestarter.java:35) at java.lang.Thread.run(Thread.java:595) Caused by: java.io.IOException: ServerFile[PersistentMap,/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/jms.state]: persistence file could not be locked. Resolve the sharing violation by ending the process currently holding the file lock or by using a different persistence directory for one or both processes. at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27) at java.lang.reflect.Constructor.newInstance(Constructor.java:494) at com.evermind.server.jms.JMSUtils.make(JMSUtils.java:1032) at com.evermind.server.jms.JMSMessages.log(JMSMessages.java:229) at com.evermind.server.jms.JMSServerMessages.severeLockPersistenceFile(JMSServerMessages.java:86) at com.evermind.server.jms.ServerFile.safeOpenFile(ServerFile.java:788) at com.evermind.server.jms.ServerFile.access$000(ServerFile.java:77) at com.evermind.server.jms.ServerFile$2.run(ServerFile.java:719) at oracle.oc4j.security.OC4JSecurity.doUnprivileged(OC4JSecurity.java:325) at com.evermind.server.jms.ServerFile.openFile(ServerFile.java:716) at com.evermind.server.jms.ServerFile.<init>(ServerFile.java:133) at com.evermind.server.jms.PersistentMap.loadFile(PersistentMap.java:100) at com.evermind.server.jms.PersistentMap.<init>(PersistentMap.java:61) at com.evermind.server.jms.JMSServer.recoverState(JMSServer.java:1823) ... 6 more 07/01/02 15:00:37 *** (SEVERE) Failed to set the internal configuration of the OC4J JMS Server with: XMLJMSServerConfig[file:/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/config/jms.xml] Jan 2, 2007 3:00:37 PM com.evermind.server.ServerMessages severeJmsServerStartupException SEVERE: Exception starting JMS server: Failed to set the internal configuration of the OC4J JMS Server with: XMLJMSServerConfig[file:/U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/config/jms.xml] Jan 2, 2007 3:00:40 PM com.evermind.server.http.HttpMessages internalErrorWhileTryingToInstantiate SEVERE: Internal error raised tyring to instantiate web-application: webapp defined in web site OC4J 10g (10.1.3) Default Web Site. Application: datatags does not exist. Error creating Web application: webapp Ready message received from Oc4jNotifier. Embedded OC4J startup time: 10000 ms. Target URL -- http://192.168.1.79:8988/SRDemoADFBC/index.jspx ... |
| 03.01.2007, 01:05:41 |
Привет! Попробуй решение в Удачи! ... |
| 03.01.2007, 17:04:49 |
http://forums.oracle.com/forums/thread.jspa?threadID=344598 ... |
| 03.01.2007, 17:05:42 |
Нет у меня *.lock файлов, да и AS вобщем-то нет. Все устанавливалось с JDeveloper-ом, включая OC4J Server. ... |
| 03.01.2007, 19:18:08 |
Relic HunterНет у меня *.lock файлов, да и AS вобщем-то нет. Все устанавливалось с JDeveloper-ом, включая OC4J Server. Эээ.. dir U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/ вообщен ничего не выводит? В Task Manager нескольких java-процессов не висит когда пускаешь пример? Relic HunterВсе устанавливалось с JDeveloper-ом, включая OC4J Server. Это понятно :), jdevstudiobase однако... ... |
| 03.01.2007, 19:31:08 |
Все тот же sysdba Relic HunterВсе устанавливалось с JDeveloper-ом, включая OC4J Server. Это понятно :), jdevstudiobase однако... Имел в виду Jdeveloper. jdevstudiobase включает в себя jdk. ... |
| 03.01.2007, 19:35:03 |
Все тот же sysdbaЭээ.. dir U:/Program Files/jdevstudio10131/jdev/system/oracle.j2ee.10.1.3.39.84/embedded-oc4j/persistence/ вообщен ничего не выводит? Volume in drive U is H Volume Serial Number is 0A33-0048 Directory of U:\Program Files\jdevstudio10131\jdev\system\oracle.j2ee.10.1.3.39.84\embedded-oc4j\persistence 01/03/2007 08:12a <DIR> . 11/28/2006 08:20a <DIR> .. 01/03/2007 08:07a <DIR> ejb 11/28/2006 08:21a 512 Oc4jJmsExceptionQueue 01/03/2007 08:09a 2,048 jms.state 3 File(s) 2,736 bytes 3 Dir(s) 68,035,805,184 bytes free Все тот же sysdbaВ Task Manager нескольких java-процессов не висит когда пускаешь пример? Было раз такое, о чем честно предупредил JDev. ... |
| 03.01.2007, 19:37:45 |
Удалось запустить OC4J Server путем удаления всего мусора из Код: plaintext Код: plaintext ... |
| 04.01.2007, 17:29:35 |
Попробуй убери jdeveloper из Programm Files в папку без пробелов. И почисть папку 'U:/Program Files/jdevstudio10131/jdev/system/*' ... |
| 04.01.2007, 17:51:19 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2147048]: |
53ms |
63ms |
| others: | 276ms |
| total: | 462ms |
