Форумы / Java [игнор отключен] [закрыт для гостей] / ZipException: Отказано в доступе
2 сообщений из 2, страница 1 из 1
    #34312412
загружаю в тесте контекст ...
Код: plaintext
1.
context =  new  ClassPathXmlApplicationContext("/WEB-INF/spring.xml");
и получаю ексепшн ...
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
org.springframework.beans.FatalBeanException: Unable to load schema mappings from location [META-INF/spring.schemas].; nested exception is java.util.zip.ZipException: Отказано в доступе
Caused by: java.util.zip.ZipException: Отказано в доступе
	at java.util.zip.ZipFile.open( Native  Method)
	at java.util.zip.ZipFile.<init>(ZipFile.java: 203 )
	at java.util.jar.JarFile.<init>(JarFile.java: 132 )
	at java.util.jar.JarFile.<init>(JarFile.java: 70 )
	at sun.net.www.protocol.jar.URLJarFile.<init>(URLJarFile.java: 56 )
	at sun.net.www.protocol.jar.URLJarFile.getJarFile(URLJarFile.java: 41 )
	at sun.net.www.protocol.jar.JarFileFactory.get(JarFileFactory.java: 78 )
	at sun.net.www.protocol.jar.JarURLConnection.connect(JarURLConnection.java: 102 )
	at sun.net.www.protocol.jar.JarURLConnection.getInputStream(JarURLConnection.java: 124 )
	at org.springframework.core.io.support.PropertiesLoaderUtils.loadAllProperties(PropertiesLoaderUtils.java: 110 )
	at org.springframework.beans.factory.xml.PluggableSchemaResolver.<init>(PluggableSchemaResolver.java: 93 )
	at org.springframework.beans.factory.xml.PluggableSchemaResolver.<init>(PluggableSchemaResolver.java: 77 )
	at org.springframework.beans.factory.xml.DelegatingEntityResolver.<init>(DelegatingEntityResolver.java: 62 )
	at org.springframework.beans.factory.xml.ResourceEntityResolver.<init>(ResourceEntityResolver.java: 63 )
	at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.<init>(XmlBeanDefinitionReader.java: 166 )
	at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java: 69 )
	at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java: 89 )
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java: 278 )
	at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java: 92 )
	at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java: 77 )
	at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java: 68 )
	at test.db.dao.BaseDAOTest.testContext(BaseDAOTest.java: 25 )
	at sun.reflect.NativeMethodAccessorImpl.invoke0( Native  Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java: 39 )
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java: 25 )
	at com.intellij.rt.execution.junit.JUnitStarter.main(JUnitStarter.java: 40 )
	at com.intellij.rt.execution.application.AppMain.main(AppMain.java: 90 )
вроде никакие процессы spring.jar не держат, тот в свою очередь нормально распаковывается и даже работает :)
пробовал spring.schemas распаковать вручную и положить в classpath, но всё равно спринг пытаеца дернуть его из jar-ника.
    #34319066
ssppeedd
такая ошибка например возникает когда не найден jar файл
тоесть, например, запускаешь
java -jar JarFile
а JarFile отсутсвует в области видимости
