JBoss и log4j: настройка JMS аппендера?
Имеем в файле log4j.xml следующее: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. так же имеется категория использующая этот аппендер. Запускаю JBoss, в логах следующее: [Log4jService$URLWatchTimerTask] Configuring from URL: resource:log4j.xml log4j error: Error while activating options for appender named [InteractionAuditor]. javax.naming.CommunicationException: Could not obtain connection to any of these urls: 127.0.0.1:1099 and discovery failed with error: javax.naming.CommunicationException: Receive timed out [Root exception is java.net.SocketTimeoutException: Receive timed out] [Root exception is javax.naming.CommunicationException: Failed to connect to server 127.0.0.1:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server 127.0.0.1:1099 [Root exception is java.net.ConnectException: В соединении отказано]]] at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1414) at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:594) at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:587) at javax.naming.InitialContext.lookup(InitialContext.java:392) at org.apache.log4j.net.JMSAppender.lookup(Unknown Source) at org.apache.log4j.net.JMSAppender.activateOptions(Unknown Source) at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:247) at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:210) at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:140) at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:153) at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:415) at org.apache.log4j.xml.DOMConfigurator.parseCategory(DOMConfigurator.java:335) at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:781) at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:666) at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:616) at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:602) at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:697) at org.jboss.logging.Log4jService$URLWatchTimerTask.reconfigure(Log4jService.java:643) at org.jboss.logging.Log4jService$URLWatchTimerTask.run(Log4jService.java:582) at org.jboss.logging.Log4jService.setup(Log4jService.java:460) at org.jboss.logging.Log4jService.createService(Log4jService.java:476) at org.jboss.system.ServiceMBeanSupport.jbossInternalCreate(ServiceMBeanSupport.java:260) at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:243) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94) at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:142) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659) at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978) at $Proxy0.create(Unknown Source) at org.jboss.system.ServiceController.create(ServiceController.java:330) at org.jboss.system.ServiceController.create(ServiceController.java:273) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94) at org.jboss.mx.server.Invocation.invoke(Invocation.java:86) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659) at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210) at $Proxy4.create(Unknown Source) at org.jboss.deployment.SARDeployer.create(SARDeployer.java:258) at org.jboss.deployment.MainDeployer.create(MainDeployer.java:969) at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:818) at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782) at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94) at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:142) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659) at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210) at $Proxy5.deploy(Unknown Source) at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482) at org.jboss.system.server.ServerImpl.start(ServerImpl.java:362) at org.jboss.Main.boot(Main.java:200) at org.jboss.Main$1.run(Main.java:490) at java.lang.Thread.run(Thread.java:619) Caused by: javax.naming.CommunicationException: Failed to connect to server 127.0.0.1:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server 127.0.0.1:1099 [Root exception is java.net.ConnectException: В соединении отказано]] at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:269) at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1385) ... 73 more Caused by: javax.naming.ServiceUnavailableException: Failed to connect to server 127.0.0.1:1099 [Root exception is java.net.ConnectException: В соединении отказано] at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:243) ... 74 more Caused by: java.net.ConnectException: В соединении отказано at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333) at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366) at java.net.Socket.connect(Socket.java:519) at java.net.Socket.connect(Socket.java:469) at java.net.Socket.<init>(Socket.java:366) at java.net.Socket.<init>(Socket.java:266) at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:84) at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:77) at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:239) ... 74 more На сколько я понимаю, log4j пытается найти очеред через jndi, и не может. Причем после этого исключения JBoss продолжает загружатся и в логах видно, как стартует сервис jndi, jnp, да и вообще все сервисы основные, в том числе и сама очередь jms/InformationAuditServiceQueue создается после приведенного выше исключения. Т.е. получается, что log4j пытается использовать сервисы/ресурсы, которых еще нет. Как это понимать? Или еще чего-нибудь где-нибудь нужно прописать? ... |
| 09.02.2007, 16:50:55 |
Можно проставить log4j.defaultInitOverride=true (либо не менять и забить на эксепшны при стартапе) и конфигурить log4j в сервлете с load-on-startup=1. Не знаю насколько это правильно, но должно работать. ... |
| 09.02.2007, 17:17:50 |
TimmМожно проставить log4j.defaultInitOverride=true (либо не менять и забить на эксепшны при стартапе) и конфигурить log4j в сервлете с load-on-startup=1. Не знаю насколько это правильно, но должно работать. В JBoss есть более адекватные средства инициализации чем "сервлет с load-on-startup=1" в виде JMX. ... |
| 09.02.2007, 17:28:36 |
Blazkowicz TimmМожно проставить log4j.defaultInitOverride=true (либо не менять и забить на эксепшны при стартапе) и конфигурить log4j в сервлете с load-on-startup=1. Не знаю насколько это правильно, но должно работать. В JBoss есть более адекватные средства инициализации чем "сервлет с load-on-startup=1" в виде JMX. Есть, никто не спорит, просто сервлета может быть достаточно. ... |
| 09.02.2007, 17:33:43 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2146687]: |
28ms |
88ms |
25ms |
85ms |
| others: | 305ms |
| total: | 590ms |
