Форумы / Java [игнор отключен] [закрыт для гостей] / JAXB и java.util.Map ?
    #34388330
sysmanx
есть код:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
@XmlRootElement
public class TodoList {
  @XmlJavaTypeAdapter(MapAdapter.class)
  public final Map items = new HashMap();
public class MapAdapter extends XmlAdapter<MapPair[],Map<String,Object>> {
    public Map<String,Object> unmarshal(MapPair[] pairs) {
        Map map = new HashMap();
        for (MapPair pair : pairs) {
            map.put(pair.key, pair.value);
        return map;
    public MapPair[] marshal(Map<String,Object> map) {
        MapPair[] pairs = new MapPair[map.size()];
        int i = 0;
        for(Map.Entry<String,Object> c: map.entrySet()){
            pairs[i++] = new MapPair(c.getKey(), c.getValue());
        return pairs;
public class MapPair {
    @XmlAttribute
    public String key;
    public Object value;
    public MapPair() {} // Required for marshalling to work
    public MapPair(String key, Object value) {
        this.key =  key;
        this.value = value;
public class Item {
  @XmlAttribute
  public String title;
  public Kind type;
  @XmlAttribute
  public String description;
public enum Kind {
  PERSONAL, WORK
public class Main{
 static public void main(String[] arg){
  try{
	  JAXBContext context = JAXBContext.newInstance(TodoList.class);
	  TodoList todo = new TodoList();
	  Item item = new Item();
	  item.title = "priva";
	  item.type = Kind.PERSONAL;
	  todo.items.put("first",item);
	  context.createMarshaller().marshal(todo,System.out);
  }catch(Exception ex){
	ex.printStackTrace(System.out);
В результате выдаёт ошибку:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
javax.xml.bind.MarshalException
 - with linked exception:
[javax.xml.bind.JAXBException: Item nor any of its super class is known to this context]
        at com.sun.xml.internal.bind.v2.runtime.MarshallerImpl.write(Unknown Source)
        at com.sun.xml.internal.bind.v2.runtime.MarshallerImpl.marshal(Unknown Source)
        at javax.xml.bind.helpers.AbstractMarshallerImpl.marshal(Unknown Source)
        at Main.main(Main.java:13)
Caused by: javax.xml.bind.JAXBException: Item nor any of its super class is known to this context
        at com.sun.xml.internal.bind.v2.runtime.XMLSerializer.reportError(Unknown Source)
        at com.sun.xml.internal.bind.v2.runtime.XMLSerializer.childAsXsiType(Unknown Source)
        at com.sun.xml.internal.bind.v2.runtime.property.SingleElementNodeProperty.serializeBody(Unk
nown Source)
        at com.sun.xml.internal.bind.v2.runtime.ClassBeanInfoImpl.serializeBody(Unknown Source)
        at com.sun.xml.internal.bind.v2.runtime.ArrayBeanInfoImpl.serializeBody(Unknown Source)
nown Source)
        at com.sun.xml.internal.bind.v2.runtime.XMLSerializer.childAsSoleContent(Unknown Source)
        at com.sun.xml.internal.bind.v2.runtime.ClassBeanInfoImpl.serializeRoot(Unknown Source)
        at com.sun.xml.internal.bind.v2.runtime.XMLSerializer.childAsRoot(Unknown Source)
        ... 4 more
        at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.getBeanInfo(Unknown Source)
        ... 15 more
Может кто знает как лечить?
MapAdapter и MapPair хотелось бы сделать универсальными.
