idea + tomcat
постоянно идея не может стартануть томкат в дебаге. Using CATALINA_HOME: C:\Program Files\java\Tomcat 5.0 Using CATALINA_TMPDIR: C:\Program Files\java\Tomcat 5.0\temp Using JAVA_HOME: C:\Program Files\java\jdk1.5.0 Connected to the target VM, address: '127.0.0.1:2155', transport: 'socket' 23.03.2007 15:07:22 org.apache.coyote.http11.Http11Protocol init INFO: Initializing Coyote HTTP/1.1 on http-8080 23.03.2007 15:07:22 org.apache.catalina.startup.Catalina load INFO: Initialization processed in 1779 ms 23.03.2007 15:07:22 org.apache.catalina.core.StandardService start INFO: Starting service Catalina 23.03.2007 15:07:22 org.apache.catalina.core.StandardEngine start INFO: Starting Servlet Engine: Apache Tomcat/5.0.28 23.03.2007 15:07:22 org.apache.catalina.core.StandardHost start INFO: XML validation disabled 23.03.2007 15:07:22 org.apache.catalina.core.StandardHost getDeployer INFO: Create Host deployer for direct deployment ( non-jmx ) 23.03.2007 15:07:23 org.apache.catalina.core.StandardHostDeployer install INFO: Processing Context configuration file URL file:C:\Documents and Settings\....\.IntelliJIdea60\system\tomcat_Unnamed_bed4392f\conf\Catalina\localhost\...xml всё, здесь стоит и чего то ждёт.. если кликнуть стоп, приложение стартует, но дебага соответсвенно нет и такой лог: atalina.stop: java.net.ConnectException: Connection refused: connect java.net.ConnectException: Connection refused: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333) at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:364) at java.net.Socket.connect(Socket.java:507) at java.net.Socket.connect(Socket.java:457) at java.net.Socket.<init>(Socket.java:365) at java.net.Socket.<init>(Socket.java:178) at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:410) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:336) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:427) 23.03.2007 15:21:45 org.apache.jk.common.ChannelSocket init INFO: JK2: ajp13 listening on /0.0.0.0:8009 что за ерунда?.. ... |
| 23.03.2007, 16:28:10 |
idea + tomcat
В списке процессов java.exe и cmd.exe не висит случайно ? ... |
| 23.03.2007, 16:38:23 |
idea + tomcat
вроде в Каталина.бат нужно что-то прописать... ... |
| 23.03.2007, 16:38:49 |
idea + tomcat
^ozzy^В списке процессов java.exe и cmd.exe не висит случайно ? оба висят. ... |
| 23.03.2007, 16:51:23 |
idea + tomcat
Макаронвроде в Каталина.бат нужно что-то прописать... что именно? ... |
| 23.03.2007, 16:51:44 |
idea + tomcat
zxczxczxczxzcz оба висят. Вот Вы их принудительно (через диспетчер задач) закройте и попробуйте еще раз запустить приложение. ... |
| 23.03.2007, 16:54:24 |
idea + tomcat
^ozzy^ zxczxczxczxzcz оба висят. Вот Вы их принудительно (через диспетчер задач) закройте и попробуйте еще раз запустить приложение. cmd стартует автоматом при запуске дебага собственно как это может влиять? ... |
| 23.03.2007, 17:01:41 |
idea + tomcat
У меня иногда происходит такая ситуация, что при завершении приложения в IDEA, Tomcat остается запущенным в системе. И не стартует, пока принудительно не закроешь java.exe ... |
| 26.03.2007, 09:31:20 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2146283]: |
25ms |
59ms |
97ms |
| others: | 303ms |
| total: | 556ms |
