Календарь для java
Здравствуйте скажите пожалуйста как можно подключить календарь в программу, чтиобы пользоваетль мог вводить даты выбирая нужнуя ему из календаря, а не вводя числа вручную. ... |
| 16.04.2007, 07:44:58 |
Календарь для java
======================================================================= JCalendar - v1.1.3 - 06/28/02 - Readme File - ======================================================================= (C)1998-2002 Kai Toedter Released under GNU Lesser General Public License (see license.html) kai@toedter.com www.toedter.com ======================================================================= THANKS I would like to thank all the people who have sent e-mails and provided bug fixes and suggestions. ======================================================================= UPDATES JCalendar is updated from time to time. Check the web site to stay informed about the updates: http://www.toedter.com ======================================================================= ... |
| 16.04.2007, 09:14:02 |
Календарь для java
Спасибо за ссылку!!!! ... |
| 16.04.2007, 09:15:12 |
Календарь для java
jikez======================================================================= JCalendar - v1.1.3 - 06/28/02 - Readme File - ======================================================================= (C)1998-2002 Kai Toedter Released under GNU Lesser General Public License (see license.html) kai@toedter.com www.toedter.com ======================================================================= THANKS I would like to thank all the people who have sent e-mails and provided bug fixes and suggestions. ======================================================================= UPDATES JCalendar is updated from time to time. Check the web site to stay informed about the updates: http://www.toedter.com ======================================================================= А никто не знает подобную штуку с поддержкой времени? Или я просто в этой не нашёл? ... |
| 19.04.2007, 09:26:33 |
Календарь для java
JDatePicker. Но она платная. Тем не менее демо-версия доступна для закачки (в ней будут присутствовать надписи в ненужных местах) Nai tiruvantel ar varyuvantel i Valar tieyanna nu vilya Aiya Eärendil Elenion Ancalima! ... |
| 19.04.2007, 09:34:24 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2145995]: |
26ms |
60ms |
65ms |
| others: | 292ms |
| total: | 504ms |
