Ant flow control
Начал разбираться с антом. Вопрос вот в чем: в таргете xxx есть таск: Код: plaintext авторThere are three possible routes that the program could take, designated by the actions A, B and C. This can be expressed in Ant as: <?xml version="1.0"?> <project name="Flow.Of.Control" default="nested-if" basedir="."> <target name="nested-if"> <condition property="condition"> <available file="fileone"/> </condition> <antcall target="then"/> <antcall target="else"/> </target> <target name="then" if="condition"> <echo>THEN BODY EXECUTED</echo> <condition property="inner-condition"> <available file="filetwo"/> </condition> <antcall target="inner.then"/> <antcall target="inner.else"/> </target> <target name="inner.then" if="inner-condition"> <echo>INNER THEN BODY EXECUTED</echo> </target> <target name="inner.else" unless="inner-condition"> <echo>INNER ELSE BODY EXECUTED</echo> </target> <target name="else" unless="condition"> <echo>ELSE BODY EXECUTED</echo> </target> </project> Но это же изврат. Подкажите как сделать проще ? ... |
| 02.08.2007, 13:43:32 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2145007]: |
32ms |
75ms |
26ms |
88ms |
| others: | 345ms |
| total: | 628ms |
