NetBeans и Hibernate. В консоли работает а в среде - нет.
Вопрос. Работаю в NetBeans с Hibernate. Файл hibernate.cfg.xml положил в каталог C:\java_projects\NetBeans\ProbaHibernate\dist\ Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. Компилирую запускаю. В окне Output выдаёт: init: deps-jar: compile: run: 0 [main] INFO util.HibernateUtil - Create Configuration 172 [main] INFO org.hibernate.cfg.Environment - Hibernate 3.2.4.sp1 188 [main] INFO org.hibernate.cfg.Environment - hibernate.properties not found 188 [main] INFO org.hibernate.cfg.Environment - Bytecode provider name : cglib 219 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4 java.sql.Timestamp handling 516 [main] INFO util.HibernateUtil - OK 516 [main] INFO util.HibernateUtil - connigure 532 [main] INFO org.hibernate.cfg.Configuration - configuring from resource: /hibernate.cfg.xml 532 [main] INFO org.hibernate.cfg.Configuration - Configuration resource: /hibernate.cfg.xml org.hibernate.HibernateException: /hibernate.cfg.xml not found Exception in thread "main" java.lang.ExceptionInInitializerError at util.HibernateUtil.<clinit>(HibernateUtil.java:41) at events.EventManager.createAndStoreEvent(EventManager.java:15) at events.EventManager.main(EventManager.java:56) Caused by: org.hibernate.HibernateException: /hibernate.cfg.xml not found at org.hibernate.util.ConfigHelper.getResourceAsStream(ConfigHelper.java:147) at org.hibernate.cfg.Configuration.getConfigurationInputStream(Configuration.java:1405) at org.hibernate.cfg.Configuration.configure(Configuration.java:1427) at org.hibernate.cfg.Configuration.configure(Configuration.java:1414) at util.HibernateUtil.<clinit>(HibernateUtil.java:31) ... 2 more Java Result: 1 BUILD SUCCESSFUL (total time: 2 seconds) ... |
| 05.08.2007, 17:17:14 |
Новичёк Java Файл hibernate.cfg.xml положил в каталог C:\java_projects\NetBeans\ProbaHibernate\dist\ Господи, почему туда запихнули-то? hibernate.cfg.xml кладите в ProbaHibernate\src\ ... |
| 07.08.2007, 17:34:48 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2144971]: |
32ms |
98ms |
26ms |
101ms |
| others: | 342ms |
| total: | 664ms |
