Форумы / Java [игнор отключен] [закрыт для гостей] / Jdeveloper, tag file и PanelPage
    #34750267
RR123
Добрый день!
сделал tag-file :
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
<?xml version = '1.0' encoding = 'windows-1251'?>
<jsp:root xmlns:jsp="http://java.sun.com/JSP/Page" version="2.0"
          xmlns:h="http://java.sun.com/jsf/html"
          xmlns:f="http://java.sun.com/jsf/core"
          xmlns:af="http://xmlns.oracle.com/adf/faces">
  <jsp:directive.attribute name="title"/>
  <jsp:directive.attribute name="icon"/>
  <f:loadBundle basename="xxx.view.resources.UIResources" var="res"/>
  <af:panelPage inlineStyle="font-family:helvetica; font-size:smaller; font-style:normal;"
                quickLinksShown="true">
    <jsp:doBody/>
    <f:facet name="branding">
      <f:subview id="branding" rendered="#{xxxProperties.drawBranding}">
        <af:objectImage source="#{xxxProperties.brandingImage}"/>
        <af:outputFormatted value="#{xxxProperties.brandingText}"/>
      </f:subview>
    </f:facet>
    <f:facet name="brandingApp">
      <f:subview id="brandingApp" rendered="#{xxxProperties.drawBrandingApp}">
        <af:objectImage source="#{xxxProperties.brandingAppImage}"/>
        <af:outputFormatted value="#{xxxProperties.brandingAppText}"/>
      </f:subview>
    </f:facet>
    <f:facet name="menuGlobal">
      <af:menuButtons var="menuGlobalOptions" value="#{menuModel.model}"
                      inlineStyle="height:32.0pt;">
        <f:facet name="nodeStamp">
          <af:commandMenuItem text="#{menuGlobalOptions.label}"
                              action="#{menuGlobalOptions.getOutcome}"
                              rendered="#{menuGlobalOptions.type=='global'}"
                              icon="#{menuGlobalOptions.icon}"
                              inlineStyle="height:32.0pt;"/>
        </f:facet>
      </af:menuButtons>
    </f:facet>
    <f:facet name="menu1">
      <af:menuTabs var="menu1Options" value="#{menuModel.model}">
          <af:commandMenuItem text="#{menu1Options.label}"
                              action="#{menu1Options.getOutcome}"
                              rendered="#{menu1Options.type=='default'}"
                              icon="#{menu1Options.icon}"/>
        </f:facet>
      </af:menuTabs>
    </f:facet>
    <f:facet name="menu2">
      <af:menuBar var="menu2Options" startDepth="1" value="#{menuModel.model}">
          <af:commandMenuItem text="#{menu2Options.label}"
                              action="#{menu2Options.getOutcome}"
                              rendered="#{menu2Options.type=='default'}"
                              disabled="#{menu2Options.readOnly}"/>
        </f:facet>
      </af:menuBar>
    </f:facet>
    <f:facet name="menu3">
      <af:menuList var="menu33Options" startDepth="2"
          <af:commandMenuItem text="#{menu33Options.label}"
                              action="#{menu33Options.getOutcome}"/>
        </f:facet>
      </af:menuList>
    </f:facet>
    <f:facet name="appCopyright"/>
    <f:facet name="appPrivacy"/>
    <f:facet name="appAbout"/>
    <f:facet name="infoSupplemental">
      <af:panelGroup layout="vertical">
        <tags:SpecDesinger/>
        <af:objectSpacer width="10" height="10"/>
        <tags:SpecTecnology/>
      </af:panelGroup>
    </f:facet>
    <f:facet name="infoUser">
      <!-- Show the Logged in user
      <af:panelGroup layout="horizontal">
        <af:objectImage source="#{UserInfo.userIcon}"
                        rendered="#{UserInfo.authenticated}"/>
        <h:outputText value="#{UserInfo.userName}" escape="false"
      </af:panelGroup>
    </f:facet>
  </af:panelPage>
</jsp:root>
этот тэг вставляю в jsfx странички вэб приложения,
при этом в runtime (по встроенным oc4j) - все работает как нужно
а в desing PanelPage отображается некорректно,
после вставки любых компонентов в этот тэг - в desing ничего не прорисовывается. Т.о. разработку можно делать только в source, что часто очень неудобно.
подозреваю, что неправильно сделал tag-file, но что неправильно - пока не понял.
если кто-то сталкивался - pls подскажите куда копать и что почитать....
фрагмент странички с использованием этого тэга:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
<?xml version='1.0' encoding='windows-1251'?>
          xmlns:afh="http://xmlns.oracle.com/adf/faces/html"
          xmlns:tags="urn:jsptagdir:/WEB-INF/tags/">
  <jsp:output omit-xml-declaration="true" doctype-root-element="HTML"
              doctype-system="http://www.w3.org/TR/html4/loose.dtd"
              doctype- public ="-//W3C//DTD HTML 4.01 Transitional//EN"/>
  <jsp:directive.page contentType="text/html;charset=windows-1251"/>
  <f:view>
    <afh:html>
      <afh:head title="#{res['xxx.application.xxx.title']}">
        <meta http-equiv="Content-Type"
              content="text/html; charset=windows-1251"/>
      </afh:head>
      <afh:body>
        <af:messages/>
        <af:form>
<!-- начало проблемного тэга -->
          <tags:XxxPagePanel>
              <af:objectImage source="#{res['xxx.application.xxx.icon']}"/>
            </af:panelGroup>
          </tags:XxxPagePanel>
<!-- конец проблемного тэга -->
        </af:form>
      </afh:body>
    </afh:html>
  </f:view>
</jsp:root>
