Mondrian под Tomcat 7
доброе время суток. Опираясь но этот http://mondrian.pentaho.com/documentation/installation.php ман. запустил Мондриан под Томкат 7. При запуске Томката получаю вот такой трейс NFO: Deploying web application directory /home/voxa/Java/AppsServers/apache-tomcat-7.0.25/webapps/mondrian [JPivot] 09 Feb 2012 00:44:01,095 ERROR [Session ] com.tonbeller.tbutils.res.JNDIResourceProvider#close: error closing context javax.naming.OperationNotSupportedException: Context is read only at org.apache.naming.NamingContext.checkWritable(NamingContext.java:962) at org.apache.naming.NamingContext.close(NamingContext.java:762) at com.tonbeller.tbutils.res.JNDIResourceProvider.close(JNDIResourceProvider.java:68) at com.tonbeller.tbutils.res.CompositeResourceProvider.close(CompositeResourceProvider.java:56) at com.tonbeller.tbutils.res.ResourcesFactory.initialize(ResourcesFactory.java:163) at com.tonbeller.tbutils.res.ResourcesFactory.<init>(ResourcesFactory.java:92) at com.tonbeller.tbutils.res.ResourcesFactory.<clinit>(ResourcesFactory.java:89) at com.tonbeller.tbutils.res.ResourcesFactoryContextListener.contextInitialized(ResourcesFactoryContextListener.java:23) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4779) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5273) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:897) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:873) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615) at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1095) at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1617) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) at java.lang.Thread.run(Thread.java:722) Feb 09, 2012 12:44:01 AM org.apache.catalina.startup.HostConfig deployDirectory На работоспособность вроде бы ника не влияет (тестовые страницы работею MDX запросы выполняются) Кто разварачивал сабжевый сервак подскажите пожалуйста Кофейник - это тот же чайник, только в Java ... |
| 09.02.2012, 02:05:37 |
Недавно была аналогичная проблема с JasperServer на Tomcat 7. На работу отчетов также не влияла. К сожалению, сейчас нет возможности найти и привести ссылку, но эта проблема известна разработчикам и пока не исправлена в 7й версии. Если версия контейнера не критична, попробуйте развернуть Мондриан на последнем релизе 6й версии. В моем случае это решило проблему. ... |
| 09.02.2012, 11:02:20 |
paiddНедавно была аналогичная проблема с JasperServer на Tomcat 7. На работу отчетов также не влияла. К сожалению, сейчас нет возможности найти и привести ссылку, но эта проблема известна разработчикам и пока не исправлена в 7й версии. Если версия контейнера не критична, попробуйте развернуть Мондриан на последнем релизе 6й версии. В моем случае это решило проблему. да не хочется последних вкусностей EE6. Спасибо за ответ ... |
| 09.02.2012, 12:34:04 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2132610]: |
38ms |
49ms |
| others: | 343ms |
| total: | 496ms |
