Никак не могу собрать ejb-проект
Проект не мой, дали разобраться и дописать кое-что, никак не могу собрать вот лог D:\Java\TDO\TDO_Metadata\src\java\ru\infosfera\startkc\tdo\metadata\ejb_api\persist\PersMd_cards_fields.java:42: illegal start of expression })) 1 error D:\Java\TDO\TDO_Core\nbproject\build-impl.xml:178: The following error occurred while executing this line: D:\Java\TDO\TDO_PM\nbproject\build-impl.xml:477: The following error occurred while executing this line: D:\Java\TDO\TDO_Common\nbproject\build-impl.xml:476: The following error occurred while executing this line: D:\Java\TDO\TDO_Metadata\nbproject\build-impl.xml:497: The following error occurred while executing this line: D:\Java\TDO\TDO_Metadata\nbproject\build-impl.xml:250: Compile failed; see the compiler error output for details. BUILD FAILED (total time: 0 seconds) ... |
| 08.06.2012, 09:33:17 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2131620]: |
53ms |
48ms |
| others: | 316ms |
| total: | 479ms |
